-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   how to set timing (http://forums.pelicanparts.com/showthread.php?t=424269)
motorracer 08-08-2008 08:19 PM
how to set timing
hi i just got done building my first 930 motor(stroker knife edge crank c2 p/c boattail cases 40 mm intake ports balanced on and on) but how do i set the ignition :ptiming thanks
motorracer 08-14-2008 04:34 AM
bump
AngM018 08-14-2008 08:55 AM
if you are talking about the dizzy, just set it statically. To do that, make sure the engine is at TDC (verify by checking cylinder #1). Then point the dizzy rotor to the notch on the dizzy casing (will be a small line that looks like someone took a chisel to the metal casing). This where spark plug #1 will go, then follow firing order listed on the engine bay sticker. Once you start her up, use a timing light to make final adjustments.
If you are talking about cam timing. do a search for my name, and cam timing. We covered it very extensivly in a thread.
