-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Elusive knocking noise (http://forums.pelicanparts.com/showthread.php?t=432704)
DonE 09-27-2008 04:50 PM
I've spent 3 weeks trying to diagnose this noise without success, so I thought I would throw it out to the list.
The knocking noise started immediately after I changed cam pulleys and idler arm pulleys to take slack out of my cam chains. This accomplished the goal. When I installed the new adjustable cam sprockets, I had to time the cams. This means that I backed off all the valve lash adjustments to their max to allow the cams to move easier without pre-load. I set the timing on the cams, installed the carrera tensioners and put it all back together.
I then went back and set the lash adjustment to all the valves and installed the valve covers.
I started the motor and heard knocking. Normally, if you prime the carrera tensioners, you will not have cam chain slap, but I did not prime the tensioners and you could hear some slap. This went away after a minute or so, but the knocking was still there. It sounded metallic and it came from the drivers side, lower rocker cover. I removed it and found a loose rocker, set the lash and put it back together.
That fixed the metallic knock, but now I have a faint knock coming from somewhere on the drivers side, top. I checked all the plugs (in case one was loose allowing exhaust to escape), all the valve lashes again, the installation of the cam chain tensioner, cam pulleys, idler arm pulleys, spray bar (to ensure the cam was getting oil), head stud torque, exhaust leaks, intake leaks.
It's a strange knock too. When first started, the engine is dead quiet. The knock starts at 2000 (or so) rpm and actually sounds more like a "tic" base on one cylinder - kind of like an exhaust pinhole leak and stays when brought back to an idle. While the car is being driven and the engine is warming up, you can hear it around from idle to 3000 rpm and speeds up with rpm, then goes away or is drown out by engine/exhaust noise above 3000. When the car warms up solidly to operating temp, the ticking starts to go away or becomes much fainter (heat - expansion somewhere?). In fact, at idle, there is no more ticking. AFR's are exactly as I expect, oil pressure is right on, idle is perfect, acceleration is perfect all the way to red line under WOT, and so on.
I then rechecked everything again and even did a compression check with normal results thinking bent valve, burned piston, etc.
Anyone have any other ideas?
GJF 09-27-2008 05:01 PM
Cylinder 1 or cylinder 3?
DonE 09-27-2008 05:20 PM
Most likely 3.
GJF 09-27-2008 06:42 PM
Do you have a stethoscope? Does it sound like maybe a rocker arm sliding side to side hitting the cam tower?
DonE 09-27-2008 07:04 PM
No stethoscope.
I guess it could be a sliding rocker arm but I would suspect the gap would have to be significant to get such as tic - loud enough to be heard over the sound of the motor. It does sound like it could be in the valve train tho.
GJF 09-27-2008 07:22 PM
I know it is a PITA. But the next time you are checking the valve clearance verify you don't have excessive side to side play. And I am sure you checked but just asking did you check the cam spocket offsets.
GJF 09-27-2008 08:11 PM
I know the rocker is a long shot especially not having this problem before. What about the scavenge pump for the turbo?
ghnat 09-27-2008 09:59 PM
Hey Don,
can't help on the tic, but are you going to be at the Petit this weekend?
turbobrat930 09-28-2008 12:29 AM
Originally Posted by ghnat (Post 4205746)
Hey Don,
He needs to..... Get his mind off the markets and onto some R&R!!!!!
WERK I 09-28-2008 10:50 AM
Don,
If you can get an ultrasonic mic, these things work great in in isolating sounds coming off the engine. These devices are more directional than conventional stethoscopes and have the added benefit of detecting exhaust leaks. They're expensive though, and a limited number of shops have them. More than likely, you are experiencing a header leak. Get under the car and search for any white traces that would emanate from any crack or gasket. On the other hand.....
When I had problems with valve lash on my car, I had little confidence in my technique. It turns out my technique was ok, but I was experiencing oil starvation to the cam. The wear on the lobes and rockers was accelerated and I found myself adjusting them more often than the norm. If you take the covers off, check the lobes for uneven wear. Check for ridges on each side of each lobe. The lobes should look almost chrome-like in their appearance.
NathanUK 09-28-2008 02:03 PM
I always have a good look at my top/inlet valve covers end to end for an equal amount of splashed oil. If they don't look even I run the engine with the covers off (wearing goggles) and check the spray bars are squirting oil. If I have any doubts I poke the holes with a pin.
DonE 09-28-2008 05:36 PM
Hey Don,
Hi Greg - I doubt it. I have a lot of studying for my CFP board exam in Nov. I'm sure I'll see you at the Oct DE tho.
DonE 09-28-2008 05:40 PM
Good point - yes I did check the new sprocket offsets.
I drove it today and it sounds like like I have a playing card in the spokes of a wheel.
DonE 09-28-2008 05:43 PM
Nathan / Dave
Thanks. Maybe one of the aviation shops I work with have the ultrasonic mic. Good idea on taking the covers off looking for oil from the spray bars. It does sound like a dry rocker tapping.
GJF 09-28-2008 06:00 PM
Don,
Those cheap stethescopes you can get at a discount auto store are good for checking exhaust leaks. I have a Snap On stethescope and I take the vibration disc with probe off and add a length of hose to the end with the motor running and move the end of the hose around the header flanges and the area where the head mates to the cylinder. If there is an leak you will definetly hear it at that specific spot. You could also just simply take a flexable section of hose and hold one enf to your ear and the other as I discribed and get simular results. Again just an idea.
When you were a kid, did you try to put a whole deck on your bike?
WERK I 09-28-2008 06:43 PM
That sounds exactly like mine did when the spray bar became partially clogged on cyl 5 & 6.
This is after the fact, but do you have an inline filter between the turbo scavenge pump and the tank? The stock turbo sump tank had a screen filter built into it and when I added the B&B headers, the tank provided did not have that feature.
Here's my horror link below.
http://forums.pelicanparts.com/showthread.php?t=369989
NathanUK 09-29-2008 11:18 AM
That's funny because it's always 5 & 6 that I've had doubts about too. There must be a reason particles end up there...
WERK I 09-29-2008 12:46 PM
Nathan,
It's always going to occur on cyl's 3 and 6 and ultimately work it's way forward because the design of the top end lubing layout. The spray bars are closed at the ends. The better question is how particles get there in the first place. Because the oil is filtered only on the engine sump return line to the tank, one must make sure ALL oil is filtered before it's returned to the tank.
Sorry for going a little off-topic. Hopefully, this is not Don's problem. This is a PIA to straighten out.
NathanUK 09-30-2008 12:09 PM
I think the particles come from condensation around the oil filler neck. I try to wipe it out when I remember, usually when I check the oil level. I've seen cokey deposits there too, just like a normal car does. I actually removed my oil tank in my 930 and cleaned it out with fuel. I had my 911 one cleaned out approx 7 years ago when I understood how it all worked...
GJF 10-03-2008 05:42 PM
Don,
Any findings?
DonE 10-03-2008 08:31 PM
Nope
I have a stethescope and listened to the lower valve covers (sounds normal) and the uppers (both sides have a slight tic, drivers side more than pax side). I listened to the cam chain covers and they were real quiet. I listened to the case - very quiet. I pulled the covers and started the motor to confirm lots of oil from the spray bars. I checked the timing of each cam in case valve touching piston - no problem. I checked the valve lash (again) and no problem. I checked side to side play on rockers and all within spec. The car runs great except for the tic sound. I am completely stumped.
sand_man 10-04-2008 03:24 AM
The scavenge pump is on the drivers side. Is it perhaps making excessive noise?
EDIT: OOPS, just read back through this and noticd that GJF mentioned it in post number 7.
lucittm 10-04-2008 06:45 AM
Sand_man's idea is good but the scavenge pump is a rotary gear pump and should not produce a "tic" sound.
I would do a compression test on the offending side, it is very easy to do. Remove the coil wire. Pull all the plugs on the driver's side and turn the engine over for 10 seconds with the gauge hose in each successive spark plug hole.
If the pressures are all within +/- 5 PSI, then you almost have to do a tear down to learn the source of the unusual sound.
If one of the cylinders is low, then you may have a partially stuck (bent? dirty?) valve. Then a leakdown test will point to the intake or exhaust.
As an alternative to mechanical investigation, try Sea-Foam or Berryman's fuel system cleaner. It costs about $5 and after a half a tank of gas, you would know if it is deposit related. As a bonus, it would clean all the gook out of your fuel system. And you are about to dump your oil anyway...
Good Luck,
Mark
WERK I 10-04-2008 12:20 PM
DonE,
Correct me if I'm wrong, but the sounds appears after the engine is up to temp or after short driving period? It is quiet when the engine is cold? You said the sound it makes is like a "card in the spokes" after you have driven it?
If rocker arms and lobes look normal, then it's got to be an exhaust leak....header flange gasket, header weld cracked, turbo flange gasket(s), wastegate flange gasket, cracked ceramic on spark plug, or.......busted head stud? But you did state your compression was good.
I'm also assuming the sound is the same whether the clutch is in or out.
beepbeep 10-04-2008 03:24 PM
To test for possible exhaust leak:
Use a lift and raise the car with engine running. Find a rubber hose and put one end into your ear and poke with other end around exhaust flanges. If you have a leak, you'll be able to hear it.
If car starts ticking when hot, it might be an exhaust crack which expands when hot.
It can also be a loose rocker.
DonE 10-04-2008 11:01 PM
Originally Posted by WERK-I (Post 4218747)
DonE,
You are correct on your assumptions. With the ticking, it sounds like one cylinder. When I place the stethescope on the valve cover, I can hear a metallic ticking. I assume that if it were exhaust related, I would not be able to hear the ticking through the valve cover.
This sprang up, from literally over-night, when I replaced the cam sprocket and cam chain idler sprocket. I had to time the cams, but that was it.
I placed the stethescope on the aftermarket turbo sump pump and it was dead quiet while running. If I had to bet, I would say that the sound seems to be coming from the intake side of cylinder #3. Also, I checked all head stud torque. I can not find any exhaust discoloration on anything either (header primary, spark plug, exhaust gasket, etc).
Goran - loose rocker, how? The lash is set properly, the rocker has little or no side to side play, the rocker shaft is in place and solid. Did I miss something?
It has to be something in the valve train for the #3 cylinder. It's dead silent for the first 30 seconds, then you can hear the tick. At idle, you have a very difficult time hearing it. At 2000 rpm, you can hear it if you know what to listen for. The hotter the engine, the less pronounced the tick. There is lots of oil from the spray bars too.
NathanUK 10-05-2008 12:21 AM
What about the heat deflectors between the cylinders? Are they tight? I think you've covered everything...
WERK I 10-05-2008 07:58 AM
DonE,
Wow, this is baffling! If it were a out-of-spec valve lash adjustment, the tick would get louder when the engine warms up since lash grows with temperature. It does sound like you isolated the area, that's the good news. What's that leave? Bad valve, valve guide, busted inner or outer valve spring.....I still lean towards a pin hole leak on the exhaust, but that's just me. :D
beepbeep 10-05-2008 10:43 AM
OK, I assume that you already inspected the rockers. Did you have a chance to inspect valve guides as well?
If this happened overnight and was triggered by tensioner job (with cam timing redone) I would say that issue probably lays within valvetrain. It would be good if you could isolate the cylinder. Then you could remove the valve cover and check for valve guide wear and wear on tappets and rocker shafts.
When you timed the cams, did you turned the engine by hand (with plugs removed) to check for valve/piston interference?
So far, I believe you could narrow the source to few things:
1. Small exhaust leak which expands/tightens with heat
2. Rocker/shaft issue, maybe it starts wandering when it heats up or shaft is pitted?
3. Slightly bent valve due to collision with piston. (timing job)
4. Excessive valve guide wear.
It's really a puzzling problem.
BoxxerSix 10-05-2008 12:15 PM
You can isolate it from being an exhaust leak by pulling spark from one cylinder at a time while motor is running. If it's a small leak when the spark goes dead, so will the leak noise. Motor will run tad rough for a few seconds but it'll help yay or nay an exhaust leak.
beepbeep 10-05-2008 02:33 PM
That's a good idea. It will also detect a worn rod bearing or loose piston tap if that is a cause of tick.
DonE 10-05-2008 05:20 PM
Thanks Adam - good suggestion.
Goran - yes, I timed the cams and turned the crank by hand.
Would an exhaust leak have such a pronounced tic through the upper valve cover?
Anyway, I'll pull the plug wires and see if it changes the noise.
BoxxerSix 10-05-2008 05:36 PM
It could yes, if it were coming from a bad sealing surface between the head and cylinder. Sometimes exhaust leak locations can be deceiving as the sound tends to travel and throw your ears off. At least it does with my ears :)
WERK I 10-26-2008 11:38 AM
DonE,
Any word on your "tick"?
DonE 10-26-2008 07:09 PM
Nope.
I've decided to disassemble the left side valve train - the cam chain pulleys, tensioner, all rockers. I'm also going to remove the plugs. Then I'll re-time the cams, adjust the valve lash and put everything back together, hoping I fixed it somehow.
ghnat 10-26-2008 07:19 PM
Don,
When you get it back together I want a ride in that beast at the track!
WERK I 10-27-2008 09:17 AM
Originally Posted by DonE (Post 4263445)
Nope.
Don,
Sorry to hear that. I have one other idea.... check your valve guides. A bad guide will give that annoying tic as well. You don't have to remove your heads to do so, but the springs and retainers have to be removed by pressurizing the cylinder and using a special clamp to remove them. Good luck to you sir.
Alan L 10-28-2008 02:07 PM
Don,
Before you pull it apart again you could try one more thing with stethescope.
I managed to isolate a very similar hard to find noise with a screw driver to ear.
Try placing scope on each cylinder and see if noise is in the bore.
I found a slightly loose wrist pin on my SC this way. Once found I could actually feel a very slight tap on the screw driver.
Same symptoms as you describe - and nothing on cold engine.
Broken valve spring?
Alan
DonE 11-02-2008 08:50 AM
Found it. The number three cylinder, exhaust valve guide. I can move the valve stem side to side with a screwdriver. It's probably less than a mm, but there is definite movement compared to all the others (no movement, absolutely none).
I guess its time for another engine drop. If I didn't drop the engine at least once per year, I just wouldn't feel right....
Alan L 11-02-2008 10:26 AM
Altho it may be worn, and worth replacing, I'm not sure that would cause a knocking noise.
How did you isolate it?
I just query it because would hate to see you put engine back in and still find noise there.
What makes you certain this is the source?
Alan
