Blitzkrieg
jly535's Avatar
Rear wheel bearing removal tool kit!!
Does anyone have a used rear wheel bearing removal kit sold on Pelican for sale? I have read everything on this subject and going to tackle myself, so if anyone is done using the tool and wants to pass it on, I don't want to pay $200 for something I am hopefully only going to use once. If not I will buy kit and sell when done for a discount. Jamie
Old 10-19-2008, 09:15 PM
I just made my own for about $15 worth of parts from Home Depot.
All I did was get a couple of pieces of PVC piping the same diameter as the bearing shoulder, the same diameter as the trailing arm, some angle iron, a long threaded rod and some nuts and big washers. Using these pieces I could pull the bearing out.
It worked very well for me - used it on my Carrera (not on the 930).
I've used the expensive kit before too, and it works great, too.
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 10-20-2008, 04:17 AM
Blitzkrieg
jly535's Avatar
its a completely different bearing setup on the rear of a 930, a little more involved. Thanx though!!
Old 10-20-2008, 10:00 AM
MEMBER # 930
waynesco1's Avatar
Remove the entire banana arm and take to a good machine shop . The 930 takes some skill and a press . You will thank your self for a few good dollars spent .
MEMBER # 930
Old 10-20-2008, 07:59 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
plus 1000 !!! Take the whole thing out,, spend the money at Harbor Freight and buy a press.. that and a gear puller and you're home free..
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 10-20-2008, 08:19 PM
