rear bumper gets very hot - does yours?
I've had my 930 a few weeks and am still getting use to it. I notice the rear bumper gets very hot to the touch - almost too hot to touch. Dash gauge shows temps in normak range for oil.
Is it normal for 930's to get hot rear bumpers? I'm wondering if the cat is plugged (82k miles). I plan to check timing, too. I guess the fuel mix could also be off, too (Digi WUR is on order). I've already checked all intercooler seals and tube seals. All either good or have been replaced and lubed. Before I go down the road of assuming this is not normal, and chasing all variables, I figured I'd ask the group.
Emery 1988 930 coupe - Silver Metallic TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Macht Schnell
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT |
Me like track days
Hotter n snot. Cannot touch the rear bumper.
P O R S C H E reflector melted right off....disappeared -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
My solution:
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
I would not worry about it. They do get hot, very hot - don't touch it!
Me like track days
cycling has-been
Hey Craig, I think I found your reflector for you: look at that red thing right above you license plate!
![]() Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
My factory bumper got so hot the paint was discolored around the area of the turbo. Craigs idea works well if you dont mind the look of the holes. I like the look, I also have used heat sheeting behind my new bumper, here is my fix....
77 930 "P Zilla" 3.2 Litre w / EFI conversion Last edited by Gumba11; 10-22-2008 at 10:15 AM.. |
Tinkering Pays!!
Craig's 930 on the Dyno?
Craig,
Your 930 on the dyno movie [in your signature] doesn't seem to be working any more?
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. |
Me like track days
Yeah, that was the old reflector that took flight some day a few months ago ;-)
Movie still works; maybe it is a firewall at your work or ?
Tinkering Pays!!
I got it working
You were right, Craig.
Priced-out of Porsches.
Yup, it gets alittle hot!
![]() My vent holes/heat remedy (I also have ThermoTech lining the inside of my rear FG bumper as well as the Carrera heat shield in front of that) it works well!
Mike SoCal |
Manassas, VA
The 965 is a little different but here is my solution. Do you know what really solves the problem?
Driving the car. With the normal airflow, the bumper stays pretty cool. When you start your car in the driveway to show your friends how cool it sounds, or you're waiting for your turn in the lineup at autocross; yes, the bumper will get hot.
1991 964 Polar Silver Metallic Turbo Coupe |
Blackbird Pilot
Good girls loose a button when it gets hot...bad girls loose a button to make it hot
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us |
Tinkering Pays!!
Mine's 245-degrees...
I measured mine after a quick spin [5-miles] around the block. mainly stop and go and in traffic. When I got home I got out my laser-meter and shot the back of the bumper. It's highest reading was in the middle at 245-degrees.
I went ahead and shot the exhaust side of the K-27, and it read 545-degrees. I did the 2-min. idle before shut down to keep the turbo bearings in good repair. How does this temp[s] sound to you guys who've been around the block here? I'm still a new-bee... By the way, I'll send a pic of the engine going back into the car...
Macht Schnell
Tinkering Pays!!
yeah, I was thinking the same thing... I guess your 20-years trumps my 3-days!!
thanks for the reply. I'm sure the neighbors will apreciate the added silence when I arrive!!
Macht Schnell
Heh, by the way, I bought mine when i lived in New Orleans, errr actually Metairie.
Tinkering Pays!!
Yes, mine has been worked on in Metairie. At Greff Motorsports. He's premium priced with quality to match.
I'll have a much bigger hand in the next rebuild. Just too new to all of this to attempt to take it on, now. I looked at your rebuild pics. Man, your car had some "gunk weight" added to it. I'd have to guess at least 10 lbs. of gunk... Great looking finished result!
Macht Schnell
