Crotchety Old Bastard
RarlyL8's Avatar
GT3 Exhaust - Teaser Pics
LOTS of R&D stuff going on right now. Thought I would share a couple of picture from this evening's entertainment. This project has been on the books for over a year and a half, looks like I may have it ready for production in a couple of weeks.
Huge props to Ben and M&K for their welding skills. Always consistent and never any slag.
The concept is simple: replace the center outlet tailpipe with a dual outlet tip. My exhaust systems are modular which means you can mix and match everything without purchasing an entire new muffler. There are currently 5 tailpipe and 3 waste gate configurations.
Old 01-26-2009, 07:57 PM
torresmd's Avatar
Looks great!
1998 993 C2S Guards Red/Black
1990 964 C2 RWB project car
2016 GT3RS White Daily driver
2018 Lamborghini Performante Gegio Telesto
Old 01-27-2009, 12:12 AM
Blackbird Pilot
Reaper930's Avatar
Damnit Brian....you pipes are bigger than mine and look cooler...... Kudos on making them - sweet product.
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 01-27-2009, 02:31 AM
Blackbird Pilot
Reaper930's Avatar
BTW what size outlet is that? 3"?
Old 01-27-2009, 02:46 AM
RarlyL8's Avatar
But yours are dual turbos ...
Yes, dual 3".
I need to trim back the 90 and add length to the tips for aesthetics. Will be done then.
Should have that done this week so rear pix by weekend.
Old 01-27-2009, 05:04 AM
great looking exhaust!! very nice!! maybe i can persuede you to fab me up something like that for a zork type setup i want to use on the track!
Old 01-27-2009, 07:03 AM
RarlyL8's Avatar
Should be do-able, will have to look at the angles.
Old 01-27-2009, 08:13 AM
Wo ist die Rennstrecke?
DonE's Avatar
Brian - is that an O2 bung I see on the pressure side of the turbo flange?
Old 01-27-2009, 05:35 PM
drb930's Avatar
Sweet!
Thanks,
Dave
3 Things To Live By - You can't be Too Rich, Too Thin, or have Too Much Horsepower!
Old 01-27-2009, 06:57 PM
RarlyL8's Avatar
Good eye Don.
Old 01-27-2009, 07:20 PM
Blackbird Pilot
Reaper930's Avatar
Yes, dual 3".
Yeah and the fact that you make me envy those tips speaks volumes as to your work
Old 01-27-2009, 10:24 PM
DonE's Avatar
NGK recommends not to put their O2 sensor upstream to the turbo (they don't like the positive pressure). This is why I mounted mine about 6in from the turbine. What O2 are you recommending with this setup?
Also, do you know of any good twin turbo header builders? Marco Manzie is impossible to contact.
Old 01-28-2009, 04:54 PM
most factory turbos have the o2 before the turbo
as to headers you may look at adapting 993 turbo headers
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 01-28-2009, 06:06 PM
Jeff Alton's Avatar
Nice looking work there guys!!!
Cheers
www.turn3autosport.com
Old 01-28-2009, 06:45 PM
RarlyL8's Avatar
Don if I were going twins I would take a serious look at the factory 993tt exchangers.
Old 01-28-2009, 08:05 PM
Forced Induction Junkie
WERK I's Avatar
Kinda of off topic, but maybe not when you think about.
Are the 996TT exh ports center-to-center dimensions the same as the 993TT? I know they used the same case, well almost anyway. I was wondering if it would another case of "flange flipping" to get these to work on earlier exhaust ports.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 01-29-2009, 06:50 AM
DonE's Avatar
Are they a direct bolt-on for a 930? If so, what size are the primaries?
Old 01-29-2009, 04:23 PM
RarlyL8's Avatar
Don, you have to flip the flanges just like the 993 N/A exchangers.
The only drawback that I could see was that the passenger's side turbo interfered with the 930 oil tank. You would need to modify the oil tank or relocate it a-la 965.
I don't recall the size of the primaries but those exchangers will support big power. You gotta love the packaging combined with real heat and OEM quality.
Worthy consideration.
Old 01-29-2009, 05:52 PM
