BOOST Question
I am having difficulties reading/understanding my boost reading. First off, I have a supercharged car, but as someone pointed out boost is boost !!!
My clock is a VDO reading in inch of mercury to the left and boost in lbs to the right (common I know), and I belive to be hook up properly, was done by PO who had the whole system done by SOK I belive. My problem,... I am seeing boost up to 5 to 5.5 lbs only in acceleration, once I am up to speed regardless of rpm my boost always level off down to 12-14 inch of mercury, therefore vaccum. Is this normal,... ? I've read somewhere that some are reading boost even at idle. There was a thread posted not long ago about how some of the 930 guys are reading boost miles on end or until gas tank is empty. Now I am wondering f I have a bad gauge, hook up at the wrong place, or my best guess I am leaking air somewhere. The car pull strong while under boost, but not as much as it should as I was told by others. Can someone describe to me what should I be seeing or expecting from my boost gauge under normal operation: ie: when boost comes on, and should it stay, how about deceleration and cruising speed. Any help would be great thanks Stephan
1992, 964 Carrera 2, Midnight Blue 1998 BMW 318ti 2004 BMW R1100S BCR 2017 BMW R1200RS 2017 BMW 435i Mpower Pkg |
Plug it into intake, between the throttle and heads. That way, you will be able to read boost and vacuum. You should be seeing vacuum when engine-braking and at light load, and boost when on full throttle.
PO maybe T-ed boost gauge into brake booster. it has a check valve that might mess up the readings. So use separate hose and find a place to connect it to on the plenum. I'm not familiar with inch, lbs etc. but you should be seeing anything between 10-100kPA absolute pressure at idle/coast and 100-200kPa on boost.
Thank you for your time, |
1 Bar = 14.7 psig
In your case 5 to 5.5 psi equals .34 to .37 Bar, well below the capability of a stock 930. Like the prior poster indicated, you might have a location issue or a bad gauge.
Al Morales 77 911 S (930 steel conversion) 88 BMW M3 79 Honda CBX |
If you read vacuum at cruse or idle you are hooked up between the throttle plate and the intake valves. Your gage is seeing what your motor sees.
If you hook it up after the compressor and before the throttle plate and there is not a relief valve of some type to vent the excess pressure, you would see boost at idle and cruse. |
1 Atm = 14.7 psi
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
I thought 1 bar was suppost to be the same as so called atmospheric press. 14.7 psi.
Pressure - Wikipedia, the free encyclopedia
Nope. 1 bar = 14.5 psi
Just for fun, Google will do instant conversions. Try Googling 1 bar = ? psi
07 Audi A4 2.0T Cabriolet - Black/Black (sold) 96 993 C2 Cabriolet - Arena Red/Tan (sold) 82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold) 58 DKW Universal - Baby Crap Yellow/Beige (sold) |
Not a Porsche, but my Procharged 5.0 (centrifigal supercharger) only sees boost during acceleration- begins around 3500 rpms, max boost at redline. At idle 14 inches and decel I am seeing 17 - 19 inches vacuum. Cruise varies 5 - 10 inches vacuum I think...
JP 86 930/4 tribute beasty 81 sc beach beater ‘55 Belair ‘40 Ford pickup |
Thanks for the reply and suggestions. I will try what some have mention and see what if any changes.
R.I.P.
You will only see boost when the engine is under load (acceleration or going up hill).
So if I was to install a water meth injection (progressive system) that rely on boost and increase with boost: where I would want to hook up this gauge?
I think my system is tapped from the "T" that connects to the brake booster, where is that exactly pre or post throttle plate? My apologies for the rookie questions, but I'm not a mechanic, but willing to learn and simply call things by what it looks to me : ex metal thingy or plastic thingy,.. ![]() Thanks for all the help
R.I.P.
typical vacuum/boost source is after the throttlebody.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/495935-how-long-boost.html Not that I am implying that anyone is lying but if there is several ways to measure boost,... this means that boost is relative to your system and can not be compare one car to another,... am I wrong ![]() Stephan
Boost is boost. On the other hand, mass air flow and resulting horsepower will vary enormously at any given boost level with charge temperature, humidity, port flow, exhaust back pressure, etc.. Also, all boost gauges are not born equal and boost pressure will vary with where you measure it in your intake path.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
So again, if I was to install water/meth injection system with my boost gauge connected where it is right now,... I would only see a little squirt here and there for less than 3-5 second at each time on a progressive injection system. I wounder if these injection system can be set to inject while the gauge reads vacuum at say a preset point of 5" mercury, which would benefit my engine while coasting??? Any thoughts
You may want to read the methanol injection thread:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/455080-methanol-injection.html
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! |
R.I.P.
