Help me understand C/R, Detonation, Etc.
Hey guys,
What I am trying to understand is, Is there an equation which correlates Boost to increased C/R?
What I am also trying to understand is what is too high of a C/R before detonation sets in or is it more complicated to that?
As many of you know I am trying to Turbocharge my SC engine again... but I want to make sure I do it safely.
The plan is to use a Euro 930 CIS, The 993 Y and HEs, along with factory IC/ Airbox etc.
The plan is to keep the boost between 0.5-0.7 bar, will the factory 930 IC be sufficient to prevent detonation, or again is it more than that?
If the Turbo Carerra had 7:1 C/R, and did not use an IC, what was the CR underboost?
I saw an engine for sale which was Turbocharged and had a 10.5:1 CR how is that operarted safely, when there is such concern for later SC engines and even my 78 with a C/R of 8.5:1 (I beleive).
I know it is is a lot of questions, but TIA for educating me.
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!---
-2001 996 Turbo
Old 02-21-2009, 04:09 AM
David's Avatar
Here's a chart from A. Graham Bell's book "Forced Induction Performance Tuning"
It's for a water cooled 4 valve engine, but shows the relationship between CR and boost.
Old 02-21-2009, 07:29 AM
Dynamohum's Avatar
Here are a couple of links to calculators, that I find handy in calculating dynamic compression ratios, octane relationships, fuel needs, IC and W/A injection gains when looking at your what if scenarios.
http://www.turbofast.com.au/javacalc.html
and this one is very handy as you can adjust for Elevation, IC, W/A and turbo efficiency and a host of other inputs.
http://www.not2fast.com/turbo/glossary/turbo_calc.shtml
Thank You for your time, Paul. We do because we can.
87 911 3.2 (Turbo conversion, build in progress, Thermal Barrier Coatings, High Pressure Dry film coatings) Modified heads, boat-tailed case, ARP hardware, OBX Header, 930 clutch disk, G50 Trans
89 5.0 Mustang convertible (For Sale)
Old 02-21-2009, 11:02 AM
Twins are more fun!
JMA-RUF's Avatar
FYI, the non-intercooled, 3.0L Turbo Carrera ran a 6.5:1 C/R. Compression was increased to 7.0:1 on the 3.3L intercooled motors from 1978 onwards.
A lot of tings come into play here, such as fuel quality (octane rating), intercooler efficiency and proper tuning.
A 3.2 Carrera can run a safe 10psi/0.7bar of boost at the stock 9.5:1 C/R with appropriate fuel delivery, ignition timing and intercooling.
James
Carrera TT
(3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's)
Old 02-21-2009, 02:23 PM
Me like track days
Craig 930 RS's Avatar
mb911 would know exactly your answer -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-21-2009, 06:00 PM
jeremy I would error on the safe side for now until you get it up and running and feel comfortable in the tuning area. maybe start with .4 bar (where I started) then slowly go upward in timing and boost levels. your stock dizzy will work fine up to approx .5 maybe .6 bar then time for a recurve. a stock IC will work fine up to .5 bar(a guess but feel it is safe) as long as you don't track it and do long bursts of boost. you may want to look at snowperformance.com for meth injection instead of an IC. thats what that 930 powered 356 does with great luck. Its all about baby steps and go from there
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 02-22-2009, 07:30 AM
Thanks for the info Ben, I guess I will go little by little.
I will have to look in the MeOH injection. It sounds interesting and besides I can get all the MeOH I could ever want at work...
Jeremy C.
-2001 996 Turbo
Old 02-22-2009, 09:26 AM
Ben, are you sure about the link? Seems to be a site dedicate to Downhill skiing.
Jeremy C.
-2001 996 Turbo
Old 02-22-2009, 09:28 AM
No but google it you will find it.
Ben
89 944,85.5 944
914-6werkshop.com
Old 02-24-2009, 07:04 AM
It is a metaphor for the slippery slope of adding boost.
'69 911 Targa w/ 3.2
Old 02-24-2009, 08:34 AM
jeremy here you go
http://www.snowperformance.net/
Ben
89 944,85.5 944
914-6werkshop.com
Old 02-24-2009, 08:51 AM
MiamiTurbo
Which kit from snowperformance
Ben,
Which kit from the snowperformance site should we use?
Alex
wanabe911 owner
1974 914 2156cc project
2005 Lotus Elise Original owner
2002 996TT Tip
Old 02-25-2009, 12:39 PM
Originally Posted by wanabe911 owner View Post
Ben,
Alex
I will look when I get a chance but I remember a thread recently with the 930 powered 356 guy talking about his kit and how well it worked.
Ben
89 944,85.5 944
914-6werkshop.com
Old 02-26-2009, 03:40 AM
There is info in Bruce Anderson's book on modifying Porsche motors on a method to compute the effective CR.
Old 02-26-2009, 07:38 PM
