Plastic fantastic air box missing vent port
Hello all,
I bought 1 of those plastic fantastic cone filter air boxes (used for $150), it looks OK, works OK. However, it did not have provisions for the vent hose from the oil tank from the turbo. So....I simple cut that line, up high, just under the intercooler & placed a small cone filter on the end. I figured...venting is venting...but now I wonder if the tank really needed to have the slight vacuum that the old air box port would have supplied?? Was I bad to just do what I did??? Mark |
Crotchety Old Bastard
That is exactly what I did. Has worked fine for several years now.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Thanks Brian...sometimes I over think stuff after the fact...just my O.C.D. kicking in I guess!
Mark |
Registered Driver
What about the vent line on the WUR. Does it need to be connected to the airbox or can it just be vented?
Ben '85 930 - Black on Black '95 993 Turbo - Silver |
Hey Helmsy,
I knew that vent line was OK to be just open to atmosphere, I put on a little plastic "T" fitting on a super short piece hose, just so no water could possibly drip into it from the tail screen above. But again, probably not needed...just the O.C.D. thing again. Mark |
Infidel
You need to run the vent off the WUR somewhere safe, so if your diaphragm splits the fuel that will jet out of it won't go all over anything hot, like your exhaust. I think Porsche vented it to the airbox so the car would bog down if the WUR went bad, or maybe that it was the safest place to send it
Jonathan. 87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines..... Old 540 BMW, XB12S Modified, for being a total hooligan
I really need to lose my a/c. makes it so "open and happy" in there.
Ryan 79 930..... among other fine German cars.
quack, i also got the same intake used and also the same breather problem. i purchased a black plastic marine fitting for a bilge pump waste water line($2.95) i grind down the threads except about a quarter inch, fed it from the inside of the intake, and it almost looks purpose built. the head inside the intake is thin and smooth, thus airflow going to the distributor is unaltered. i too feel there should be some vac. there, if nothing else it keeps oil vapors under control. as for the wur vent i was just using a u shaped 4 inch hose. i am going ti vent in safe direction
Actually there are no oil vapors. Mine has been this way for several years now.
How about the aftermarket drip tanks that don't have a vent? I have wondered if it should be vented but figured it was OK since most folks with aftermarket headers have this setup.
Eric
87 930 Coupe Red, K27S, Kokeln IC, Rarlyl8 Headers system, Tial 46MM, .9 Bar. "Lola" 81 911SC Coupe Guards Red, Stock. "Zippy" |
The aftermarket drip tanks can become fluid/air locked or overburdened in applications where a non-KKK/K27 turbo is used. This can be due to incorrect system modification to compensate for the different oil supply requirements of aftermarket turbos, such as using oil to cool water cooled turbochargers. The vent line can relieve cavitation and become a "stand pipe" if oil temporarily backs up in the system. The vent line can also quickly indicate a falure in a very messy way.
