Parts help needed 86 930
Need help in finding a parts source. The EFI installation left me with a blow off valve that vents to the atmosphere instead of back into the air inlet tube as with the stock set up. This gives me that "whoosh" sound whenever I lift the gas and I HATE this sound....(sound like a bus door whooshing open.)
Any idea where I can source a set-up which routes the blow-off valve into the air intake tubing? Thanks, Drew 86 930 Autronic EFI conversion
Drew 86 930 |
Forced Induction Junkie
Pics of your engine and induction system layout would help greatly in giving you some suggestions.
Thanx
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
I'll try to get some picks tomorrow.
Set up is simple.... the pre-turbo inlet pipe has a simple cone filter on it, no sensors, nothing, just straight to the turbo. I have a Kokelin IC which the current blow-off valve is mounted to on the backside and vents to the atmosphere instead of the pre-turbo inlet pipe. Does anyone make this inlet pipe with an attachment point for the other end of the blow-off valve?
Drew 86 930 |
Answering my own question...... I now remember that prior to my EFI installation I had the 965 rubber elbow with the molded diverter valve opening in it.
This was not the case after the EFI installation and this is what I need to install. Thanks everyone for stoking my brain. Drew 86 930 Autronic EFI conversion
Drew 86 930 |
