wiring diagram 965
Hi.
Do someone have a wiring diagram for the 965. I am installing a zeitronix wideband, and need to know witch wires to conect to! Terje |
![]() Found the source in my blog. Took the signal from the open box to the very left in the picture above. The cable was black with a green stripe on my car. |
i need all the cables, rpm, grund, TPS, .....
Hi.
I didn't mean to be rude, but my English isn't that good. But if someone can help me with the cables, i would be happy. Maybe staffanbe can write to me in Swedish. Terje |
There is actually not much to add, but let me know if I should explain it in Swedish. Anyway, I installed my Zeitronix databox inside the console. I took the power and ground from the car stereo cables. I use the Zeitronix boost sender and have a vacume hose from manifold (where the EZ69 gets it's boost read) all the way to the console where the Zeitronix boost sender is located (I also have a Blitz electronic boost controller that uses this hose). I don't think (but I'm not sure) there is such thing as a throttle position signal on our cars. There is a throttle position box on the throttle body, but I think it only can indicate that there is 0%, 7% and 66% of throttle or something like that. |
