V2.0 993 turbo Y for 930's new design
I decided to revise this design for the 993 heat exchangers. this is 100%volute and is about as good as it gets without center mounting the turbo. I have the ID and OD polished right now so I will have better pictures next week. this is not going to replace my first version but is an option for some. what do you think?
![]() and this is a picture of the first(v1) more stock application
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Damn Ben,
That is pure sex!!!
JP 86 930/4 tribute beasty 81 sc beach beater ‘55 Belair ‘40 Ford pickup |
thanks thats what I was shooting for
Low Speed, High Drag
So will this put the turbo in the stock location on the 930?
FWIW, I like this version better!
Jeremy C. Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham) ----Nothing is far away in this car!--- -2001 996 Turbo |
yes that has been my limiting factor every time.
JCC I time studied this one from start to finish I had a HUGE amount of time in it bascially doubleing the cost to produce so you kind of get what you pay for
Forced Induction Junkie
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
And now the most important question.... would I be able to keep my Monty on there?
Not sure It does work with rarly's muffler. I will be fitting up this week though and can verify
twin 38mm v band tials
What is the benefit of the new design?
Which gaskets are used at the exit of the HEs 928 111 127 02 or 930 111 192 06?
I have a gross of the gaskets so don't worry. as to the design it is just a bit better wastegate circuit but a huge cool factor
MikeD '87 930 |
I am going to make 1 Wg dump into the back of the center dump tail pipe and the other wastegate will flare to 3" so it match's and the from the rear of the car it will look like a GT3
That should be an interesting look.. So one Turbo w/ 2 Waste gates?
RGruppe #180 So many cars.. so little time!! |
yup its a volute system (twin scroll setup) though the turbo is not
Smart quod bastardus
Give yourself some room for thermal expansion between the watsegate bodies....they look awful close together. The flow path to each wastegate is much better than previous design where you reverse direction on one of them.
Damn you do great work man! I regret buying my GSF headers 2 years ago. Will you do a trade in policy, ha,ha?
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
How much credit for a 2 year old GSF header system with heat?
