Send a message via AIM to FlashGordon
ATTN: 930 WIZARDS...Help Me Solve This!
Hey guys. I'm hoping you can help me trouble shoot a persistent problem that I am having with my '87 930. The car will die on me (stall) while driving and will not restart. However, after it sits for a couple of hours, it will start up no problem at all. The problem can occur 5 minutes into the drive or 30 minutes etc. Sometimes it will stutter before the stall and sometimes just cut-off. My wrench has been unable to get the problem to surface while at the shop, and so, has been unable to solve/fix it. He gave me a substitute ignition box, fuel relays, and alligator clip to jump the #6 fuse to try when it happened again. It happened again last night and none of these remedies worked. Any thoughts?
Old 05-25-2009, 12:56 PM
magic930's Avatar
When I first bought my car it had a similar problem, replaced the ignition and coil with an MSD 6AL and it worked fine after that.
The Coil is suspect if a cool down fixes the problem. They are only $50 and easy to replace.
Old 05-25-2009, 09:53 PM
The next thing I would check would be the overboost sensor. Easy to check without throwing any more money at the problem. When the problem occurs again, simply ground the wire going to the sensor. If the car starts, you have found the problem. Let us know if this is the issue,
Dave
Old 05-25-2009, 11:46 PM
Thanks for the thoughts guys! Keep 'em coming.
Old 05-26-2009, 03:24 PM
David's Avatar
Check those other items first and then check fuel pressure, not WUR pressure, but fuel pressure. Your fuel pump may be dying. Do you live in a hot climate? Could be vapor lock if the pump can't maintain enough pressure.
Old 05-26-2009, 03:58 PM
torresmd's Avatar
Dave
I may be having an issue with the overboost sensor as well. Is that the yellow guy in the engine compartment? Also it is grounded by a brown wire already. What do you mean or how do you ground the wire going to the sensor?
1998 993 C2S Guards Red/Black
1990 964 C2 RWB project car
2016 GT3RS White Daily driver
2018 Lamborghini Performante Gegio Telesto
Old 05-26-2009, 04:28 PM
wcc wcc is offline
wcc's Avatar
Yup...
http://forums.pelicanparts.com/showthread.php?t=404147&highlight=overboost+sensor+pic
Bill
997.2
Old 05-26-2009, 04:32 PM
mark houghton's Avatar
Don't confuse the relay with the sensor. Both, of course, work in collusion with each other. The sensor itself is located at the front end of the boost recirculation valve. It looks similar to a typical temperature sensor, and has just a single wire going to it. It's contacts are normally closed (keeps the wire connected to ground)and opens on excessive boost....signalling the yellow relay to shut down the fuel pumps.
Unplug the sensor and the pumps won't run. Hook the wire to ground and you've bypassed the thing.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 05-26-2009, 07:23 PM
torresmd's Avatar
My car is dead in my garage right now. I turn the key to position 2 and no humming of the fuel pumps. So this has happened two months ago and my mechanic replaced the relay and fuel pump. Two days ago the car won't start. So I need to get the car to my mechanic. I was planning on getting a tow but if I can bypass the sensor and get the car to start that would be great. Problem is I need pics. Connect this wire here etc. Help! I hate getting my car towed.
Old 05-26-2009, 07:51 PM
A picture tells a thousand words....
Try these. The first is of the infamous yellow overboost fuel cuttoff relay, the second shows a wire used to jump across terminals 87 and 87A - which will turn on your fuel pumps regardless of whether the boost sensor (the third photo) is connected or not. Of course, the ignition key has to be on. This little jump bypasses the need for the air flow metering plate at the fuel head to be deflected before the pumps will normally run. Stock wiring, unless someone has messed with it, will not allow the pumps to run with the key on unless you're cranking the engine and drawing air across the metering plate, thus deflecting it and triggering a small micro switch to turn on the pumps. Similarly, the pumps will stop if the engine dies (no air moving across the metering plate). It's a safey feature should the car get in an accident, keeping fuel from continuing to pump.
Old 05-27-2009, 07:31 AM
torresmd's Avatar
Thanks Mark, that is good info. My car is on the tow truck as we speak. If this happens again, maybe I will try this.
Old 05-27-2009, 09:02 AM
Mark, that's a great post. Thanks for taking the time to do that. I love these forums. Information is power, brotha!
Old 05-27-2009, 03:00 PM
torresmd's Avatar
I hate to keep asking silly questions but in the second picture showing the jump, do those wires go anywhere or is that just a loop? Cannot really tell from the pic. I just want to be clear on this, just in case I try this some day.
Old 05-28-2009, 08:07 AM
Send a message via AIM to Chuck Jones
I believe a "jump" is simply a loop that directly connects the two contact points.
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 05-28-2009, 08:38 AM
Boost Freak
Maxx1's Avatar
If all else fails, my car had the same symptoms.... the ignition went bad, made the car stall and that's when I went to a MSD which fixed the prob.
82 Porsche 930 Euro, black, 31K miles.
Factory stock other than k27 turbo, B&B headers, GHL exhaust, Tial F40, 1 bar wastegate, MSD 6A ignition, 8" and 9" Fuch upgrade, H4 Xenon headlamps and a 930S steering wheel.
Old 05-28-2009, 09:35 AM
Yep, just a loop (it's about 10" longer than it needs to be). That little red wire resides in my glove box for emergencies.
Old 05-28-2009, 09:38 AM
Also, one of the fuel pumps relay or air lock due to "may be" bad gas...
Old 05-28-2009, 12:48 PM
