I pulled my 88-930 engine because of a bad valve guide on # 2 cylinder. while i am having the heads refinished at Ultimate Heads. would it make sense to hone the Cylinders and put new rings?? The car has 58k miles and the leak down was very good except # 2 that was leaking by the exhaust valve!! #4-5-6 were 4% and #1&3 were 6%
Any Input would be great! Thanks Clark
88-930 Black / Tan 89-930 Grand Prix Wht 70 Trans Am Ram Air III 4 speed 74 Bronco Sport 302 Auto Beach truck for the Mutts |
Having the engine out and half appart, I would.
Forced Induction Junkie
Hone the cylinders? You've opened Pandora's Box on that subject!
![]() Personally, I would recommend taking the cylinders out and spec-ing them for taper and oval. If they spec out ok and you still see the cross-hatch, deglaze them with a Scotch-Brite pad and put new rings in.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Smart quod bastardus
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
I agree with the scotchbrit idea. The 930's have nikasil coating, not alusil, so there shouldn't be any issue with changing rings.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Thanks for all the input Guys!! There are a lot of cross hatches still visible!! I will take your good advise and check the specs and the pistons well!! I like the Scotch Brite idea! just to deglaze and put new rings in!! I will keep you posted! Thanks Again! Clark
+1 on checking those ring lands. You'll be rebuilding that engine in no time flat if they are worn.
