-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Question about additional oil cooler (http://forums.pelicanparts.com/showthread.php?t=479813)
equality72521 06-13-2009 11:19 AM
I have removed the rear a/c condenser and have been wondering about putting an oil cooler in it's place. It's has as much air passing through it as the I/C and will also pass air through it at idle where a front mount really only sees cooling while moving. This would also eliminate the lines sets running to the front or the car. Good or bad idea?
930cabman 06-13-2009 05:43 PM
cool
Mark,
Locating an oil cooler in that place may add to the heat load on the engine. My 930 runs kinda hot, I have been considering either a front mounted cooler(with new front valance) or has anyone used the rear fenderwell to mount an oilk cooler?
John G
DonE 06-13-2009 05:53 PM
You'll heat the air going into the IC and to the engine. Front left or right fender or center seem to be the best places.
dsiegel360 06-13-2009 07:25 PM
I've got 2 carrera coolers up front and it doesn't do the job. In no way can it handle a track day (500-600hp). I will finally bite the bullet and get the center mount cooler. But, perhaps there is a way to hollow out the bulk head so that a cooler could be set back- allowing air to pass behind. Air would get to the cooler by cutting some holes in the stock valance. Anyone done it?
A930Rocket 06-14-2009 02:57 AM
There was a write up recently from someone who did what you propose to the bulkhead. While adding holes to the front valance would help, you really need a large opening.
If you're putting out 500 HP, you need the front oil cooler. Oil coolers in the fender wells just do not get the needed air flow at a stand still or moving.
Miguel Antonett 06-14-2009 07:48 AM
I believe it would get the engine bay hotter acting as a heat sink and not improve cooling.
DonE 06-14-2009 05:02 PM
You might want to look at Fluidyne's oil coolers. I use a singe and dual pass cooler in the front two fenders with good results. I use a C2 front bumper with two vents each side which at speed keeps the oil in check. In traffic, it gets warm.
dsiegel360 06-14-2009 05:34 PM
Hey Don,
Can you post some pics?
What kind of temps do you see?
Do you track the car?
thanks.
