Twins are more fun!
Flame ringing cylinders/barrels?
As the subject states, what do you guys think of such a mod for big boost motors running at around 1.4bar?
Is it still required, even if you use high quality ARP fasteners? Is the expense worth the extra insurance?
James Carrera TT (3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's) |
I'll assume you mean between the cylinder and the head:
At 1.4 bar I'd think it was mandatory. Even at 1 bar, it's a really good idea.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Twins are more fun!
Thanks - just trying to toss up between an extra point in compression for off-boost response, or leaving it at 7.0:1 and having the flame ring mod done to support more boost.
I think I'd prefer more boost
is this 1 bar rule also for the 965 engines that have a head to cylinder gasket?
i am thinking about those flame rings to my engine, what different options are there? |
Infidel
Even in the 993tt they say go no higher than 1.1bar to be safe on an otherwise stock engine
Jonathan. 87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines..... Old 540 BMW, XB12S Modified, for being a total hooligan
Twins are more fun!
spjuvern, the 965 motor already has a sealing head gasket, which offers better sealing than no head gasket at all (from what I'm told), but flame ringing offers the best sealing at very high boost levels.
Infidel
With the stock 930 engine i'm told that anything above 1.0bar will cause issues, so anything above this will need head sealing along with other mods to keep things together. I think running an air cooled engine at 1.4bar is suicidal, unless it's a race engine that is stripped and rebuilt like clockwork. For a street engine 1.2bar is the upper end of the envelope, and requires more than just head sealing for longevity.
James..
Personally I'd do both. - 7.5:1 is a nice bump to get a little low end grunt.. (add SC cams) - Flame rings are nice "while you're in there" insurance.. Then you've got the best of both worlds.. not too radical, but a nice bump with a safety factor.. Just to note: - Have a bud that did 8.0:1 JEs, flame rings etc.. runs at .8 bar and it's twin turbo'd - My current motor 3.5 Ltr, 7.5:1, flame ringed, and is set at 1 bar. No issues and runs like a scalded dog!! That is if I can ever finish my other little mods and clean-ups and get back to the pavement. Hope that helps..
RGruppe #180 So many cars.. so little time!! |
Twins are more fun!
I read somewhere Juan Ruiz was running flamed rings and was running some pretty extreme boost (1.4+ bar) on his Carrera motor.
I'm told for a street car that sees occasional boost, it'd be fine? Mind you, this is for an EFI'd 3.3 Carrera motor, not CIS.
The same guy who did Juans heads did mine. Juan runs a bit more boost than that
It is alot more than boost to consider. 22 pounds from a k27 and 22 pounds from a t76 are two different beasts.
Me like track days
After seeing the heads skip around my cylinder barrels - I'd say it's a must for .9 and above and cars which see track use.
I have em.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Navin Johnson
Even in our race cars we tune the engine in the 0.8~1.4/1.6 bar range ... and limit the boost at 1.4, and don't recommend operating the engine for long periods at 1.4
I know Bill drives his 935c at 0.8 mostly.. Putting 670 hp onto the dyno @ 0.8 is cool.. blistering the tires and loosing accuracy @ 1.0+ is way cool. Nirosist rings are a must do "while you in there" mod... the only con is the extra expense, the pros are less expense in the future...
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Wo ist die Rennstrecke?
Not many know how to do this mod correctly, so beware. I flame ringed mine for the same reason Craig mentioned.
My rings are made of stainless and are cut .001 taller than needed for proper compression and even fit. The mod requires at least ARP head studs - no stock Porsche stuff. Once you do the mod, you'll have to cut any new heads or cylinders from here on. Before you say you won't be buying any new cylinders or heads, you might want to reconsider 1.4 bar. You can eat pistons and cylinders within the blink of an eye at that boost. I have the scrap metal to prove it. |
Me like track days
I think it was about $800 - for the work and tooling involved, it was a bargain - pics soon below.
Me like track days
![]() Flame rings installed in barrels: ![]() ![]()
Twins are more fun!
Great pics, Craig. Thanks
![]() I remember reading that Protomotive made their rings out of some sort of aluminium, so they have the same expansion rate as the other metals around it?
how about this rings http://www.cometic.com/files/CometicPhuzion.pdf
any one had a experience with Porsche engine and those? i have them in a Lexus twin turbo V8 we built |
Smart quod bastardus
Cant you alleviate the heads moving around under higher boost pressure by increasing the head stud torques? Of course this requires ARP studs for safety, but the mean effect is increasing the compressive preload on the cylinder head so that you don't get separation between head and cylinder at high boost pressures.
I know that flame rings are a better solution, but the cost and stuff outlined above is a factor, when switching to higher quality studs and increasing torque is cheaper, since likely you would switch studs during a rebuild anyway. Thoughts?
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
Me like track days
Already used ARP studs - they move around like you would not believe - .8 bar and hard track use.
If I were doing a new P&C rebuild and my car saw track use, the rings would be a 100% no-brainer.
Absolutely Niro Rings and studs
why limit to 1.4 bar try 2.0 bar you will fall in love
10.76@139-1/4 mile 0-1 mile 193MPH I Love to Shine Cars
