930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
Igniion Woes
Car cut off while driving, engine will start in the crank position but when key is released(key on) it stalls . I can keep the car running if i keep slight pressure in between crank and key on. But to make it better its not the ignition switch swapped out with a brand new one and it does the same thing with new one.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 08-14-2009, 05:57 PM
930gt-40r's Avatar
Do you got an alarm in there? Check that if you do and make sure it isnt disconnecting the circuit.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 08-14-2009, 06:24 PM
mark houghton's Avatar
OK, so you can rule out the switch then...which means it may not be ignition related. Maybe fuel related?
Let's force your fuel pumps to run to narrow this down a bit. Cranking the engine moves air across the metering plate/arm connected to the fuel distributor, deflecting it enough to engage a switch and start the pumps. Perhaps your metering arm is not moving far enough to trip the switch. Try this: Unplug the blue connector to the switch back behind the top of the fuel head. The pumps should run continuously with the key in the on position. Try starting it then.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 08-14-2009, 07:01 PM
h20cooled7's Avatar
Will try to disconnect air folw meter switch and let you know!
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 08-14-2009, 07:25 PM
h20cooled7's Avatar
No dice disconnected and wont start, wire diagrams are good but dont tell you where anything is located
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 08-15-2009, 06:32 AM
h20cooled7's Avatar
jump the air contact relay and runs fine , checking siganl now
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 08-15-2009, 07:08 AM
h20cooled7's Avatar
brown with black trace and ground for air contact switch melted together. system was disconnected for this reason. ran a new wire with new ground runs beautiful!
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 08-15-2009, 12:32 PM
