-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Help - Where Do These Hoses Go? (http://forums.pelicanparts.com/showthread.php?t=502480)
73ess 10-01-2009 12:25 AM
This evening I removed the intercooler on my 88 930 and found a few disconnected hoses, a cork plug and a loose wire in various areas of the engine. I need some help in determining where the hoses should go and more importantly, what the effect is on the engine performance with them disconnected as they are now. I'm guessing that some of them might have been disconnected in order to pass California emissions testing, but that's just a guess. Anyway, here they are. Any help very much appreciated!
Loose Hose #1 - Has a screw inserted in the loose end.
http://i11.photobucket.com/albums/a171/munkmunk/930%20Engine/P1200694.jpg
Loose Hose #2 - Also has a screw inserted in the loose end.
http://i11.photobucket.com/albums/a171/munkmunk/930%20Engine/P1200695.jpg
Loose Hose #3
http://i11.photobucket.com/albums/a171/munkmunk/930%20Engine/P1200696.jpg
Cork Inserted in Air Filter Housing. Why? Also, looks like a loose ground wire?
http://i11.photobucket.com/albums/a171/munkmunk/930%20Engine/P1200697.jpg
See hose slipped off, but not sure if done on purpose or just slipped off?
http://i11.photobucket.com/albums/a171/munkmunk/930%20Engine/P1200700.jpg
Should A Hose Be Connected to this Inlet Under Air Filter Housing?
http://i11.photobucket.com/albums/a171/munkmunk/930%20Engine/P1200701.jpg
Just a Full View of My Engine With Intercooler Removed
http://i11.photobucket.com/albums/a171/munkmunk/930%20Engine/P1200702.jpg
Looks Like a Torn Paper Air Hose in this Photo? But not sure.
http://i11.photobucket.com/albums/a171/munkmunk/930%20Engine/P1200704.jpg
What Is the Red Thingee and Should a Wire Be Connected to the Second Terminal?
http://i11.photobucket.com/albums/a171/munkmunk/930%20Engine/P1200706.jpg
Those are all the areas I could find that looked like possible contributors to my hesitation problem. Or maybe they are just disconnected for a reason. My engine has some modifications from stock. K27 turbocharger, not sure what model number , but here are a couple photos of it:
http://i11.photobucket.com/albums/a171/munkmunk/930%20Engine/P1200707.jpg
http://i11.photobucket.com/albums/a171/munkmunk/930%20Engine/P1200710.jpg
Also I have a GHL exhaust and twin plug ignition.
beepbeep 10-01-2009 01:26 AM
Please upload the images into forum instead of linking to photobucket. Links are broken.
Charlienofun 10-01-2009 06:32 AM
73ess,
I'm just over in Oakland, although my 2ndary air injection system is removed if you want to look at my 87 in reference PM me and we can get together.
Charlie
AFM744 10-01-2009 07:57 AM
I'm down in Campbell, and have completely removed all my smog plumbing, as well as my vacuum limiter and AAR. Let me know if I can help!
Without this clutter my engine compartment is just wonderfully uncluttered. I can remove my spark plugs completely unimpeded! Without the vac-lim I get nice burble off-throttle. Without the AAR I have to tend to the throttle for the first 30-sec after I start it cold (otherwise it'll idle at 600rpm, not good on cold oil IMHO). But none of this crap is missed.
I removed so much crap, and WEIGHT, from my engine bay I had to re-lower the rear end!
73ess 10-01-2009 11:22 AM
Sorry for the broken photo links. They are working now.
A930Rocket 10-01-2009 05:00 PM
See my answers in bold red
Loose Hose #2 - Also has a screw inserted in the loose end. I think this goes to the timed switch near the breather cover.
Loose Hose #3 This is a vent. It's OK.
Cork Inserted in Air Filter Housing. Why? Capped off when the new intercooler was installed. Cap it off properly.
Also, looks like a loose ground wire? Probably from grounding the overboost switch.
See hose slipped off, but not sure if done on purpose or just slipped off? Should be connected or you can remove all those hoses and solinoids.
Should A Hose Be Connected to this Inlet Under Air Filter Housing? Should be the hose from the WUR vent below.
Looks Like a Torn Paper Air Hose in this Photo? But not sure. I can't really tell what I'm looking at.
What Is the Red Thingee and Should a Wire Be Connected to the Second Terminal? Overboost switch. I don't recall that it needs a ground.
Those are all the areas I could find that looked like possible contributors to my hesitation problem. Or maybe they are just disconnected for a reason. My engine has some modifications from stock. K27 turbocharger, not sure what model number, but here are a couple photos of it:
Looks like it might be a K27-7006.
Also I have a GHL exhaust and twin plug ignition. Are you sure it's twin plugged? I only see six plug wires (and they are looking tired:( ).
73ess 10-02-2009 04:14 PM
A930Rocket,
Thanks for your reply. Here are my responses in red, to some of your responses:
Can you describe what the timed switch looks like? Also, what does the breather cover look like?
Who sells the proper cap?
Also I have a GHL exhaust and twin plug ignition. Are you sure it's twin plugged? I only see six plug wires (and they are looking tired ).
Yep, it's definitely twin plugged.
A930Rocket 10-02-2009 06:48 PM
Originally Posted by 73ess (Post 4932305)
A930Rocket,
Can you describe what the timed switch looks like? Also, what does the breather cover look like? See attached. The thermo switch is located on the breather.
http://forums.pelicanparts.com/uploa...1254534249.jpg
Who sells the proper cap? Best bet would be too measure it and go to a auto parts or hardware store to find a rubber cap that you can clamp off or use a plastic tie. That would look best, but you could find a short length of hose and clamp a short bolt in there to plug it.
You're a lucky man. Is that a 12 lead dizzy cap? That's worth a lot of money if it is.
A930Rocket 10-02-2009 06:55 PM
Vaccum lines...
http://forums.pelicanparts.com/uploa...1254534871.jpg
http://forums.pelicanparts.com/uploa...1254534946.jpg
willtel 10-02-2009 07:05 PM
I believe it is the highlighted part in this image. The breather cover is part number 34 on the diagram.
http://imgur.com/e8Zrn.jpg
As long as no unfiltered air is getting into that hole the cap is proper.
