1987 930 fuse block question?
i hope someone here can help. on my 87 930, i am trying to figure out the function of fuse #'s 6, 7, and 8 on the middle fuse block in the trunk compartment?
also, what are they fuses to...what do they operate?
thank you for your help.
best,
pcb
p.s. also posted in the 911 tech section.
Old 10-09-2009, 03:37 PM
help...please.
Old 10-09-2009, 04:05 PM
Ferraripete;
The fuse box panel legend on my '87 agrees with my factory Owner's Manual...#6 is fresh air blower, cigarette lighter, and rear window defroster. #7 is rear window wiper, intermittent windscreen wipers, and nozzle jet heating. # 8 is "indicator lights" and backup lamp. #9 is front left turn signal and #10 is the right side. I'm pretty sure I'm correct.
Scott - 1987 930: 3.45L Supertec engine w/GT3 crank, California Motor Sports upgraded 930 trans, modified suspension, Zuffenhaus 9's and 11's, black on black..."The Black (Financial) Hole"
Old 10-09-2009, 05:02 PM
thank you so much. what a great help. do you know by chance what is the proper fuse for each? are they all 25 amp?
thank you again!
Old 10-09-2009, 05:07 PM
A930Rocket's Avatar
Old 10-09-2009, 07:15 PM
thank you both. i am all set for now.
best,
pcb
Old 10-10-2009, 07:30 AM
