Jesper's Avatar
Problems with my Turbo boost unit???
Hello friends
Lately I had problems with my Turbo boost readiness. The needle in me boost gauge is a bit flickering. When my turbo blows at approx. 3500 rpm the needle falls to the bottom of the gauge. There is nothing wrong with the turbo pressure on the engine, just the readiness on the gauge.
I think its the sender, who creates the problems. Anyone who knows where to buy these senders? Does Pelican have them?
Thank you very much
Best regards
Jesper
1969 911T "The White Lady" Stainless DANSK
1976 930 "The Phantom" RarlyL8
aka The Beauty and the Beast
Old 11-02-2009, 01:28 AM
sudo apt-get purge 930
equality72521's Avatar
Pelican sells them, they are a little pricy. Porsche 911 & Carrera Gauges and Miscellaneous - Page 4
--clutch-monkey
Old 11-02-2009, 04:43 AM
Smart quod bastardus
fredmeister's Avatar
Why bother replacing it? That gage in the tachometer is uselessly inaccurate anyway.
You should consider installing a mechanical boost gage in the clock location.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 11-02-2009, 05:04 AM
proffighter's Avatar
I had the same issue
The problem was bad earth. As far as I can see your sensor get earth through housing via pipe. Pipe has bad earth in cause of connections with rubbers... so just connect for testing a good mass from engine with free (right on pic) connector and see if it helps
Roland
930 Turbo '81 Too many modifications to list
Old 11-02-2009, 05:36 AM
mark houghton's Avatar
Whip out your handy-dandy ohm meter and a source of compressed air and test the resistance of your sender unit at various pressures. Here's a handy graph plot. Mine tested out at 112 ohms at .8 bar.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/468501-boost-sensor-resistance-data.html
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 11-02-2009, 07:51 AM
Jesper's Avatar
Hello guys
Thanks so much for your help, I really appreciate the answers. It was the bad earth who caused the strange readiness.
[Fredmeister] I thought of installing the big gauge instead of the clock, but where to buy?
Thanks again ;-)
Best regards
Jesper
Old 11-03-2009, 03:51 AM
