Getting away from a stop has improved so much in my car since installing the MSD 8762 boost retard box and advancing the base timing by turning the distributor.
These cars need alot more ignition advance than the stock emission control oriented setup gives to run as good as possible before boost starts.
My car is so much more fun to drive now since doing that and I havn't got it tuned optimumly yet.
There's alot more information about all that in Keiths thread on timing that is on page 2 now until someone posts in it again.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/500986-ultimate-930-distributor-advance-retard-timing-turbo-lag-msd-mod-thread.html
Old 11-13-2009, 12:05 PM
tj930's Avatar
Okay, 2 pictures which may interest you... Post up yours - let's see whatcha got!
Old 11-13-2009, 01:27 PM
Send a message via Skype™ to djdawson2
You're going to have to coach me a bit... I haven't dumped my data from the GTech on to a computer yet. Where did you get the app that allows you to view the files.
I think I'm going to have to dig into my instruction manual
Old 11-13-2009, 01:55 PM
tj930's Avatar
Well if you go to GTech's web site, you can download it - I think this is the link.
http://www.gtechprosupport.com/support/pass/2.0.0/GtechPass20install.exe
You might need an (old-fashioned) serial wire to link to your PC. But, on the forum, there's a guy there with a 4WD 996tt who also dared not 'launch the car' - comparing drags - up until about 30mph, I was ahead... Then
Old 11-13-2009, 02:16 PM
OK... my GTech actually came with a serial connector... I should be able to figure this out.
Old 11-13-2009, 02:20 PM
tj930's Avatar
Well, you may have to get your shovel out and dig up one of those Personal Computers with an archaic 'serial port' (somewhere about the Jurassic period )
But, as I say, you can go to the Website's GTech Forum and actually download 'Drag runs' from all sorts of cars from all over the World. (I was really surprised to find that my old wreck was waaaaaaaaaaaaay quicker than about 90% of the cars that were on there )
Old 11-13-2009, 03:08 PM
Originally Posted by tom84930 View Post
Forwheeler:
If I recall correctly, the 8/41 r&p was in the neighborhood of $2000. The transformation is mindblowing. i'm way too old to be street racing, but I must admit to a couple of stupid, but illustrative lapses. A little over a year ago I blew away a Mercedes AMG63 off of a stoplight for a couple hundred yards before I regained my senses and braked. This past spring i did the same thing to a Z06 between two stoplights. The car's freeway behaviour is definitey altered by significantly higher cruising rpms. It's a tradeoff I don't mind. If you can find s fellow-930 owner with an 8/41 or 8/37 it would be good to take a drive before you commit. If you happen to be in Minnesots between April and November I'd happily lend you mine.
I have the Andial 8/41. I cannot imagine getting a better holeshot than I do. I walked a modded mustang and I didn't drop the clutch, I let it out and then stepped on the gas afterwards from IDLE and still got instant redline in first gear, in 2nd gear I walked away.
The problem with 8/41 is that it is ONLY for the holeshot IMO. The rest of the time first gear is uselessly short. 4th gear is also too short although breath-taking in acceleration.
Custom gearing is better IMO. I need a longer 1st and 4th.
However if hard acceleration is your only goal, the 8/41 is PERFECT and I do not think you could change it for the better. Even a computer simlulation game which lets me customize gears on a 930 shows the 8/41 set-up is the fastest possible combo for acceleration.
Old 11-13-2009, 03:24 PM
Crap, now I'm going to have to get a G-Tech to play with!
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 11-14-2009, 09:35 AM
Infidel
JBL930's Avatar
Tom, that second run gives you a 60-130mph of 17 seconds!! That's really slow! You can hit about 132-134 mph in 3rd with stock wheels and a stock 4 speed, you need to hit the rev limitter but you'll get there.
I've not heard of this GTech device, most use the Drifbox or AX22, but i don't doubt this device does the same thing. I've never bothered doing a 0-60 run, just don't think it's sympathetic on the car, it's a much better performace measurement doing a rolling start, wheel spin and clutch control don't really come to play then.
Looking at when you are hard on the throttle, with no gear change involed, 50 to 80mph comes up in 3.21 seconds which is respectable.
Would be really good if you could do a slow roll in 2nd from about 30mph, then plant your foot until up near the red line, change to 3rd and leave your foot there until you hit the limitter, that graph would be far more telling
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 11-14-2009, 07:13 PM
Maybe custom gears are the way to go. I think I will consider only lowering 3rd since 1st and 2nd are pretty good the way they are.
When on DE days I spend most of the time in 2nd and 3rd and try to take some turns in 3rd and it lugs too much but 2nd would be too low.
As an FYI, I talked to someone at Motor Meister the other day about a R&P set and they quoted my $2800. They told me that they don't sell many anymore but sell 3.6 kits for about the same price instead.
Old 11-15-2009, 02:59 PM
Banned
If you do a search in the "911 Engine Rebuilding" forum for "Motor Meister", I bet you will NOT want to send any of your money their way . . .
Old 11-15-2009, 03:26 PM
Thanks for the heads up.
Old 11-16-2009, 05:15 AM
Never do business with Motor Meiser for any reason. Sure they may do something for you and it is okay but they are hard core criminals so you would be supporting the wrong business in these economic times and we want the good businesses to survive.
And yeah, a shorter third is amazing. I recommend 3rd to about 115-120 mph like mine.
Old 11-16-2009, 05:37 AM
Originally Posted by djdawson2 View Post
Not sure what the "feeling" is about the use of the G-Tech on this forum... but I wanted to test a little prior to changing my turbo and intercooler, just as a sort of baseline.
I've had very positive experiences with the G-Tech in the past, having used it while doing runs at a dragstrip, with the largest error being 6/100's of a second.
Anyway... my car is an '89 that is essentially stock with the exception of Brian's muffler. I live in Colorado, and I did my runs at slightly above 5000ft.
0-60's were repeatedly right at 6 seconds. 1/4 mile runs were also a very consistent 14.1 @ 107mph.
One thing I learned, is that it seems there's no good way to launch this car. I tried a half dozen different methods... most resulting in a major bog, and one that was too much for the clutch. Regardless of the type of launch, the results were always about the same. The telltale figure is the 60 foot time. I was never able to get below 2.5 seconds, which is very poor. I routinely have been able to get 1.6 second results out of my other cars.
I'll be installing the K27 7200 with a B&B intercooler soon. It will be interesting to see what sort of change those provide.
That's it....
Couple thoughts...
Obviously altitude has an effect on acceleration and power.
The GT is accurate but can be fooled by up and down vertical motions from the vehicle, translating that motion into more distance travelled to reach speed i.e. slightly slower times. I know my 930 reaches for the sky between shifts when I go thru the gears quickly.
Also the 1989 is over 100 lbs heavier than an '88 which is heavier than a '79, ect...
So those are just three variables to start with anyway.
If you have 17"inch tires you give up a little in the holeshot with taller effective gearing.
So you can imagine yourself giving away maybe a second if all the above play a role. And yet 6 seconds in real world terms is very fast, and nobody normally duplicates magazine testing times in the real world anyway.
Most magazine tests have the 930s in the low five second range and just cracking the 13s at maybe 112 mph so you are getting consistent times which are solid.
Old 11-16-2009, 05:50 AM
tj930's Avatar
Well the Porsche quoted time for a '78 RoW 930 was 5.4 seconds but - in the hands of their own test driver - I heard they managed something like 4.6 seconds. (Though smashed the flywheel in the process, I believe!) Certainly low-5s should be 'doable'.
My car was doing 60ft in about 2.2 seconds, so 3s does suggest something being wrong somewhere
Old 11-16-2009, 06:05 AM
Do you remember what ratio your 3rd is?
Old 11-16-2009, 06:30 AM
When you do this, do you remove the vacuum line from the distributor and let the MSD handle all the retard or do you use them in combination?
Old 11-16-2009, 08:52 AM
I left both vacuum lines on the '87 USA distributor and turned it clockwise advancing it as far as the adjustment slot allows without pulling the distributor out and reindexing it one more gear tooth.
I'm scared to remove the vacuum retard line so far because I don't know where the timing would go under boost then. Just too risky.
I need to get some kind of degree wheel or tape that can be attached to the crank pulley and has the degree marks on the edge so it will be visable when pointing a timing light down at it before I experiment with timing safely.
At the moment I have the MSD 8762 set to retard timing 2 degrees for each psi of boost starting at 5psi but I will probably change that a little with more experimenting. I run maximum boost 1 - 1.1 bar or around 15 psi with street gas, usually chevron high test.
The motor has stock 7:1 pistons and cylinders, 964 cams, Garretson long neck half bay intercooler, and B&B headers.
It has fuel enrichment with a modified IA fuel head and Brian Leask adjustable WUR to control it.
Old 11-16-2009, 10:12 AM
My third gear is the factory third. The overall ring and pinion was just changed to the 8/41 from stock. I think you would have 9/38 ring and pinion stock....
I can tell you that my 3rd redlines at 115 or so and that is as short as you would ever want to go. I think 120 mph might be perfect for full acceleration.
Bruce anderson's 911 performance handbook has all the possible gear ratios and mph in the back.
Looking at the book a 26/26 gear at 6800 rpms gives 120 mph with a 9/38 ring and pinion. That would be devestating acceleration and just a touch taller than what I have. A 27/26 would put you at 126 mph and stock I think is about 134 mph at 6800 rpms. The 126 mph gear seems like a very nice compromise because your gear would not seem too short either.
You would want to double check those gears numbers yourself...
Old 11-16-2009, 10:33 AM
