Knock Sensor w. 3.3 CIS
Does anyone use knock sensors on a 965 3.3 turbo engine?
I am using the Clewett Engineering XDi2 dual plug crankfire kit, which has knock sensor retard capability. However, there seems to be a consensus that the 3.3 CIS engine is too noisy to effectively use knock sensors.
I would greatly appreciate any input.
Cheers.
Old 02-03-2010, 06:01 PM
sjf911's Avatar
You might want to read through this thread:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/405586-knock-sensor.html
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 02-03-2010, 06:28 PM
Wer bremst verliert
JohnJL's Avatar
Mines not a 965 but it is an aircooled, boosted motor. I use a Bosche adapted from a 993 bridge across 4-5-6 cylinders, feeding my Adaptronic ECU.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 02-03-2010, 07:31 PM
How long have you had it and what is your experience with it?
Do you feel that it falsely retards due to noise that is not related to knock?
Old 02-03-2010, 08:13 PM
Originally Posted by sjf911 View Post
I have actually posted this thread after reading the one you are referring to.
Unfortunately, the other thread seems to be mainly based on hearsay rather than on factual experience. I would like to get feedback from people who either have or had it installed on their engine.
Cheers.
Old 02-03-2010, 08:23 PM
I posted a quote from Steve Weiner of Rennsport in that thread. Speak to the source if you consider it hearsay:
Steve Weiner
Rennsport Systems
Portland, Oregon
503.244.0990
E-mail: porsche@rennsportsystems.com
Old 02-03-2010, 09:31 PM
Steve Weiner
Rennsport Systems
Portland, Oregon
503.244.0990
didn't he state that he uses it for tuning purposes only, but advises against keeping it on the engine?
I already have a system that can detect knock, but I don't have the sensors installed as there seems to be some controversy about the effectiveness of using them on the 3.3 engine.
Old 02-04-2010, 05:19 AM
This post makes it sound like closed loop knock control:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/229355-thoughts-combo-please.html#post1998268
Old 02-04-2010, 05:42 AM
Wer bremst verliert
JohnJL's Avatar
I've had it on about 6 months, including ~15 hours on the dyno altogether. I've found power falls off before I get knocking so how we have the timing and fuel mapped it doesnt interfere very often. I originally installed it because I didnt know thats how this motor was going to behave.
Old 02-04-2010, 03:11 PM
Thanks for the link. I will contact Steve and get his opinion whether this would also work on a 3.3
Cheers.
Old 02-04-2010, 05:03 PM
...I originally installed it because I didnt know thats how this motor was going to behave.
Knowing what you know now, would you install it again?
Old 02-04-2010, 05:09 PM
Wer bremst verliert
JohnJL's Avatar
Definately. I'm upping the boost to 15psi now.
Old 02-04-2010, 05:32 PM
Excellent. Thanks for your input.
Old 02-04-2010, 07:37 PM
Les Garten has a Tec III, but I don't know if he has them enabled.
Old 02-04-2010, 08:22 PM
I contacted Steve re knock sensor and his take is that it is not feasible on a CIS motor. Oh well...
Old 02-05-2010, 03:22 PM
Wer bremst verliert
JohnJL's Avatar
I know for a fact that Raymo also runs one in his CIS motor. He tapped the breather cover and installed it there. He used it for tuning, I've seen his logs and we talked about it this morning.
Old 02-05-2010, 05:08 PM
I would like to hear more about his setup.
I was told that the kock sensor would require either MAP or MAF along with throttle position, and RPM to be truly effective.
Old 02-05-2010, 05:19 PM
Did he say he tried it on a CIS engine? I'm guessing he said it wouldn't work because that's a mechanical system with no sensors to read.
The SafeGuard has a processor and onboard MAP sensor, so it reads load and RPM.
Decel or light loads can cause false knock, so software ignores the knock sensor if the onboard MAP sensor sees more than five inches of vacuum.
Also, the program has a detection window to listen for knock at the appropriate time.
I'm pretty sure Steve wasn't aware of these points.
There's a lot more I would like to say about the detection algorithm, but it's proprietary. Unfortunately, saying nothing gives the impression there is nothing to brag about.
Revealing details also has drawbacks. One, it gives the competition a starting point. Second, it gives the armchair detractors an opportunity to say "Why did you do it that way, here's how I would have done it..."
It's already happened to me on another forum. The original forum where I posted the information totally ignored it, so I gave away secrets for nothing, then got hit over the head with them later by someone that posts links to knock papers, hoping someone will design what he wants.
AIEEEE! (Marvel Comics scream).
NASIOC - View Single Post - The Knock Box
Old 02-05-2010, 09:47 PM
John,
are you saying that it does work with CIS?
I honestly do not understand too much about this topic and how the Safeguard works. I am using CIS with a XDi2 ignition system that has knock sensing capability. Can I use the Safeguard in combination with the XDi2 and how would it work w/o throttle position, RPM, and MAP/MAF inputs?
Old 02-05-2010, 10:21 PM
SafeGuard reads RPM and has an onboard MAP sensor to read load.
J&S Eight Channel Interceptor
I would have to check with Electromotive to see if it's compatible with their DFU.
If not, our Vampire system will work, but it requires MSD 8870 coil spacers. These install under the coils and allow access to the coil negative signal, required by the Vampire.
J&S Vampire
Old 02-05-2010, 11:55 PM
