Hesitation Problem
Guys...hope all is well.
I took my stock '87 911 turbo out yesterday after sitting for approx two months. When I got it out to the highway I noticed some hesitation around 3k rpm (when boost started to come on). After 3700 all was smooth.... Any thoughts? Thanks in advance for your help..... |
Sounds like it could be fuel mixture or ignition issue. Did you put any fuel stabilizer in the tank before the 2 month lay up? Stored with the gas tank full?
I'd go through the basic tune-up checklist, check fuel pressure, check plugs, wires, cap & rotor, set ignition timing, etc...start with the basics. |
Could be an O'ring in the IC plumbing about to go, starting to leak when boost pressure builds. That would cause a pig rich condition and associated loss of power. One of many possibilities.
Follow Jacob's thoughts, though. Check all the basics first. |
Everything they said.... Plus-chk all hoses,ignition-electrical,mechanical-Take your time--get a chair and sit behind the car,ponder,chk-list,&get to work... For me I did it...AND still couldn't figure it out...Finally pulling the plugs/looking at them,,,Gave me my answer.. Maybe some Marvel myst. oil/gas line will clear it up. |
Same thing happened to me last year....and became worse over time. Mine was a sticky fuel head plunger..cured in 20 minutes my running Techron concentrate in the fuel....cheap option.
| All times are GMT -8. The time now is 04:39 PM. |
