Turbo pressure pipe removal? Little help please:)
I need to remove the pipe seen top diagram with the number 16 on it from here:
Pelican Parts - Product Information: 999-701-473-40-M213
Anyone have any idea how to remove it? It`s inside some shroud and i cannot remove it however i jiggle it.
Got tips for me here?
Thx,
Oheggem
PS. Car is a 79 930
Old 03-18-2010, 12:07 PM
Crotchety Old Bastard
RarlyL8's Avatar
That link takes me to an O-ring.
Old 03-18-2010, 12:38 PM
sudo apt-get purge 930
equality72521's Avatar
If you click on images and then go to the "view diagram" link it shows the pipe. It's the one that connects the inlet of the turbo to the plenum assembly.
--clutch-monkey
Old 03-18-2010, 01:20 PM
mark houghton's Avatar
Yep, and a couple of hose clamps should be all that's keeping it in place. I don't understand the comment about it being in some sort of shroud.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 03-18-2010, 01:47 PM
A930Rocket's Avatar
Engine tin maybe? It's a pita to remove, with lots of twists and turns, but it can be done. You may need to remove certain parts to make it easier.
Old 03-18-2010, 01:54 PM
RarlyL8's Avatar
Ah yes I got it.
The turbo down pipe is not easy to remove in the car. You need to get everything out of the way as the pipe is one piece and goes 90* under the tin.
Old 03-18-2010, 02:06 PM
Exactly. The pipe has two bends and gets stuck on the turbo and the other pipe going to the IC. The rubber sleeve was cracked at the turbo end and i cannot change it as it is.
What is that shroud? Do i need it? Looks like it separates the turbo intake and pressure pipes maby?
If i need to remove the bumper, anyone got a good DIY how to?
Thx
Old 03-18-2010, 02:44 PM
Not sure about this shroud you speak of. Are you referring to the black engine tin?
--clutch-monkey
Old 03-18-2010, 04:00 PM
Most likely yes. It`s thin metal holed out for pipes etc. I`m going to work on it tomorrow. I`ll take some photos then
Old 03-18-2010, 04:27 PM
RarlyL8's Avatar
If you are just changing the rubber sleeve then the pipe does not have to be removed. Loosen both clamps and slide a tiny screwdriver around the perimeter of the rubber sleeve to loosen it. Do the same up top. Now you can rotate the pipe toward you and pull it back away from the turbo. Should be able to remove the sleeve and install a new one at that point.
Old 03-18-2010, 07:07 PM
7.0:1 > 11.3:1 > 7.0:1
I recall this being a bugger to remove. Think I had to drop the rear of the engine down a few inches to get the "S" pipe out of the engine tin.
Old 03-18-2010, 09:54 PM
