R.I.P.
drmatera's Avatar
My latest mod. idle hands are the devil's playground
I'm going to prefice this by saying i am in NO WAY going to reproduce, market, sell, give away, rent, lend or condone this.
Here is the latest from my twisted mind. you're saying to yourself " so what? you put a new exhaust on your 930", then you say, "is that a coating on the pipe? looks silver". Well aluminum is silvery in color
Old 03-28-2010, 01:28 PM
R.I.P.
drmatera's Avatar
yes, it's aluminum. from the flange to the tailpipe tip.
yes, i am aware aluminum melts in the 800* area. Yes, i am aware for road racing this would NOT hold up AT ALL. But it's all in fun and thats what hor rodding is all about.
Sounds pretty good as well.
Old 03-28-2010, 01:32 PM
7.0:1 > 11.3:1 > 7.0:1
Yup, idle hands. Nice work.
Old 03-28-2010, 04:02 PM
Nothing wrong with experimenting and trying something different, keep at it!
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 03-28-2010, 05:27 PM
Crotchety Old Bastard
RarlyL8's Avatar
You may see temperatures 1000*F higher than the melting point of aluminum in the neck area. Please show pictures of what the looks like as I can't quite imagine it.
Old 03-28-2010, 09:13 PM
R.I.P.
drmatera's Avatar
the flange off the turbo is 1/2" thick aluminum. The tubing going to the muffler is .120" wall but the muffler is only .083" (we'll see how that holds up). The real unknown is how well the "U" turn will hold up. It's a "donut" we sell and it's really for intercooler piping and .065" wall. It provided me with the tightest radius in one piece but if it blows out i'll replace it with 2 90*'s in the thick wall. The car sounds good, i'll video it and post for all to hear.
Old 03-29-2010, 12:26 PM
TurboKraft's Avatar
Mad doctor at work! Love it.
Drag racers have been doing it for years. Why not try on a Porsche? What's the worst that'll happen -- it'll melt at the turbo and get loud?
Go for it!
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 03-29-2010, 02:49 PM
Champagne on Beer Budget
HelmetHead's Avatar
I wish I could Tig like that!
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 03-29-2010, 03:54 PM
R.I.P.
drmatera's Avatar
Go for it!
true.
funny thing is i had just a 24" long straight pipe with no muffler on it before. It weighs 5.75 pounds. This whole contraption weighs 5 pounds and the car sounds much better
Old 03-29-2010, 04:36 PM
RarlyL8's Avatar
Nothing ventured nothing gained. As a one-off in a specific lower-than-tyical heat application it may last for a little while. That design is pretty much how my mufflers look and they weigh 12 pounds in 321 stainless. I would love to use aluminum as it is less expensive and lighter but it is nowhere near as durable as 321. You have seen those pictures of cherry red glowing turbos yes? That would turn your muffler into a vulcano.
Is your muffler packed or a perforated chamber?
Old 03-29-2010, 09:18 PM
Max Sluiter
Flieger's Avatar
Maybe you could give the inside ceramic coating if there is a process like powdercoating using ceramic. I guess that would require a "firing" that would melt Aluminum. Maybe a liquid dip?
Old 03-29-2010, 09:33 PM
R.I.P.
drmatera's Avatar
I thought about some sort of coating on the inside but not sure what it would do to the muffler packing. We made the muffler out of perforated aluminum rolled into a tube shape then stuffed into the 4" tube with stainless packing material.
Old 03-30-2010, 12:32 PM
R.I.P.
drmatera's Avatar
Brian, I did use your design for this set-up as it looks to give a bit quieter exhaust note due to the longer tubing. I'm going to the drag strip Wed night so we'll see if it stays on.
Old 03-30-2010, 12:37 PM
RarlyL8's Avatar
If your engine is in good tune with propper AFRs you should not see crazy heat like some of my mufflers have been exposed to. I would LOVE to use aluminum but it just isn't practical for all the various applications and range (or lack of) of tune.
Please do report back as I have never personally seen aluminum used in a turbo application. N/A typically produces a lot less localized heat.
Old 03-30-2010, 08:59 PM
Max Sluiter
Flieger's Avatar
As an FYI tidbit,
Inconel (Nickel alloy of ~30% Chrome and about ~5% Iron) is used for headers to save weight. It is actually similar density to Stainless Steels but it has a much higher resistance to heat. It is stronger (by weight) than SS at high temperatures. Therefore, F1 teams or high-budget racers can use paper-thin Inconel tubing to save on materials and weight. The problem is that it work hardens quickly and is very easy to fold/bend with tube walls than thin.
Old 03-30-2010, 09:16 PM
R.I.P.
drmatera's Avatar
alot of my drag racing customers use aluminum exhaut on their turbo cars. They are after light weight and low price. Even if they have to replace the pipes at the end of the season it's still a whole lot cheaper than exotic materials. I keep my a/f on the fat side (10.5 @ WOT) so we'll see how well it holds up.
I would never recommend aluminum for road racing or any kind of extended WOT situations
Old 03-31-2010, 06:55 AM
RarlyL8's Avatar
That is a great application for this material, short term high performance.
We worked up a set of headers in inconel. Cost for materials alone was going to be $5000. Wow!
Old 03-31-2010, 07:07 AM
R.I.P.
drmatera's Avatar
yikes
Old 03-31-2010, 08:33 AM
Brian, did your customer actually go ahead with the inconel system? Bragging rights or to save 2 oz? Where can I find customers like this.
A friend used aluminum for the rear half of the exhaust on a turbo road race car. To my surprise it lived.
Old 03-31-2010, 04:41 PM
RarlyL8's Avatar
The inconel headers were bagged by the client due to a personal issue that affected financing. He did pay for all the R&D work and some fixturing costs which was very nice.
LOVE the ditty under your screen name.
Old 03-31-2010, 07:58 PM
