not boosting
I have a stock 1977 930, recently purchased. I noticed it is not boosting at all, factory Gage does not move also. My plan was to tear it apart anyway. That was allot of fun, I don't think it has ever been apart all the bolts were a bear to get off. The turbo was not froze, spins freely, minimal play. so it should be working. So what should i look for regarding the lack of boost.
I don't hear any turbo noise either. Thanks Danny |
So in 2nd gear you pull out to overtake something and you don't hear the wastegate make "WARRRP" noises?
What kind of performance are you getting? 0-62mph in 6 seconds? Or more than that? Is the car reeeeally slow? I'm sure others on this forum can give you more accurate and detailed instructions, but it's either going to be:
Thanks for the advise. The car is a new purchase. Car ran fine, just had no power for what a turbo should do and it made no noise from spoiling or The waiste gate being open. I have the whole exhaust system and turbo off the car. Plan on replacing or rebuiding the stock turbo. It had some play and possible oil leak.
Also may need to check your waste gate, it might be stuck open.
Or the BOV valve is stuck open. And check all the seals at the throttle body and turbo up pipe. |
Waiste gate closed tight. BOV looks closed. I have not taken that apart. I can see it from one of the intake pipes. I plan on changing the seals for good measure.
| All times are GMT -8. The time now is 03:04 PM. |
