1986 930 Engine is in, but I have a few loose ends and could use an assist.
I bought an 86 930 with the engine taken out by the PO. I've had the motor rebuilt, installed new fuel, pumps, and a long list of other work.
The engine is back in, clutch adjusted, throttle cable adjusted, and the fuel lines I believe are finished. However there is a hose near the fuel filter that I don't see a home for. Also, there are two electrical connectors all by their lonesome. The lamda system is not going to be used, as I went to an msd ignition. Also, the air pump has been removed. I'm thinking perhaps the connectors aren't going to be used?
Does anybody know off hand what these are for?
Also, not sure where this goes to either.It's by the oil fill tube.
Many thanks for any help!
Chris
Old 09-27-2017, 02:39 PM
full quack's Avatar
Send a message via Yahoo to full quack
Well mines an '84 euro model, so not sure on the hose coming from behind the fuel accumulator (picture #1), or the black electrical connector, but the green connector (picture #2) goes to your "warm up" fuel injector on the back side of the fuel air meter plate housing (the unit with the paper towels covering the opening in your picture) and I think the missing hose to the bottom of the oil mist separator (picture #3) comes off the triangle housing on the top of the block behind the alternator/fan housing, but I might have that backwards, and the top hose goes to the triangle housing???
Hopefully my memory is correct, I'm sure others will chime in with advise/corrections as well.
Mark
Old 09-27-2017, 03:50 PM
It's kinda too dark to see the plugs but these two photos show the ones I think you are showing us...In the first picture, the black plug 2/3 of the way up from the bottom of the picture and 2/3 of the way to the left side of the pic. The green one where Mark says...
Old 09-27-2017, 03:58 PM
Once the fuel head comes off, this one pops up, too...
Old 09-27-2017, 04:22 PM
Thank you very much guys. The pictures were super helpful. I have the green one connected, but I don't have that thing that the black one plugs into. Is that the frequency valve or something?
I'm running a euro 930 fuel head with upgraded injectors and lines too. Maybe I don't need whatever the thing I circled is.
Thanks Again I really appreciate the help.
Old 09-27-2017, 04:29 PM
full quack's Avatar
correction
Yeh, my memory sucks.
The hose connection on the oil separator bottom goes down thru the engine surround sheet metal via a hose and then back up to the remote oil tank.
Mark
Old 09-27-2017, 05:49 PM
Thanks for the picture Mark. I have those hoses hooked up wrong for sure.
Old 09-27-2017, 05:53 PM
full quack's Avatar
Yes that is the frequency valve as pictured in your copied photo from iceman.
Mine is an '84 euro, thus euro fuel head...and I have no frequency valve.
I also have no yellow over boost relay, no air pump or any Lamda stuff...just clean and simple euro spec., no US stuff at all.
Mark
Old 09-27-2017, 05:55 PM
I had Hellen Keller come over to help and she found where the fuel line goes....
Seems I'm missing a connector or maybe the end got cut off.
I'm guessing I need this line that goes to the fuel pump?
Fuel Line 91135606607 - Genuine Porsche - 911-356-066-07 | Pelican Parts
Old 09-27-2017, 06:16 PM
Grrr....
I've identified the fuel line that the PO cut. It has a concave threaded male connector on one end and a banjo fitting on the other end where it connects to the rear fuel pump. I'm guessing it's NLA as I can't find a part number anywhere.
Thanks again for the information.
Old 09-28-2017, 06:24 AM
http://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?command=DWsearch&make=POR&description=93035606802
I think this is it?
Edit.
No banjo fitting. It could be 930 356 081 02
Derrick
Old 09-28-2017, 06:44 AM
930 356 081 02 has the banjo but the other end is the same as what I'm trying to connect to. I'm starting to think maybe something else is not right?
Old 09-28-2017, 06:56 AM
This is the banjo under the car.
This is where I believe it connects to.
Old 09-28-2017, 07:01 AM
Maybe the fuel lines are routed incorrectly?
It should be rear pump to accumulator to filter to CIS.
The line with the flair and Tee in it is the return line connection.
Derrick
Old 09-28-2017, 07:15 AM
The GREEN connector is the safety switch on the front (car direction) of the air flow meter, fuel pumps ground through this when airflow meter plate is displaced.
The BLUE connector is the CSV
The line off the canister vents overboard.
Old 09-28-2017, 09:31 AM
Well, I made some progress yesterday. A big thank you to Mr. Bob Farmer. He hooked me up with a fuel line and some oil separator hoses that I was missing. Unfortunately, I still need hose 5 in this diagram part# 93010739100
I was able to cobble something toghether for the time being,
but I'd rather it not be a permanent solution.
The fuel pumps are running and no gas leaks, but it wouldn't fire up. My MSD switch power is connected to the CDI box wiring, but I'm not getting +12v with the key on. So, I gave up for the night and it pained me to be defeated. On the flip side my neighbors were probably unknowingly overjoyed.
I found a thread about jumping an ignition delay relay. I'm going to try that and continue tracking down my electrical issue.
Anyhow, thanks all for the help. I'm hoping that I'm close to getting this thing back on the road.
Old 09-29-2017, 05:54 AM
