bruni911's Avatar
Fuel acumulator?
Are there any difference in fuel accumulator?
They look the same as the normal 911.
I have a 87 930 ,and was wondering because i have a early 80s 911 one they look the same but are they different inside?
Old 06-27-2010, 01:43 PM
nreed's Avatar
I guess the trick would be to look up the part numbers and see if they are the same or different.
Norm '86 930
AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL
HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear)
Old 06-27-2010, 06:32 PM
there are many fuel accumulators. besides number of ports 2,3 etc.. the amount of fuel they hold(cc,s) is important too.
Old 06-28-2010, 09:06 AM
I'm curious about this also. I just replaced an accumulator in my 77 and the replacement / superseded part was significantly smaller in capacity. Cured the problem. But, maybe I'm being hyper-sensative, I swear I feel a new slight miss at part throttle. I'm really wondering about the AF ratios under load..........
Tinker
Old 07-03-2010, 08:50 PM
Just changed my accumulator and filter which made the car run uber rich. The old accumulator was a lot bigger than the new one. Adjusted AF´s and toight as a tiger now.
Old bits
New bits
Old 07-04-2010, 01:18 AM
dh930turbo's Avatar
I've just changed both on mine and fingers crossed it has cured a few issues???
Frenchstick.......on your 'before' picture that fuel filter looks a very old design, any idea how old that would have been, could it have been te original?
When ever i replace servicable items now i always use a Sharpie to put a date on the new part for future reference.
"Racing is life... everything before and after is just waiting." Steve McQueen as Michael Delaney in 'Le Mans'
Old 07-04-2010, 01:37 AM
Aaahh... as ashamed as I am to say, it could have well been . It was a Bosch filter and surprisingly had little gunk in it when opened. To be changed a bit more frequently from now on.
Old 07-04-2010, 03:48 AM
