What is this sensor on a 930
I am trying to figure "what's what" on my newly acquired 911 with a 930 motor.
Is the red sensor below a "boost pressure sensor"? I noticed there is not a wire on the other pole. The wire that is attached goes to the coil. If it is the boost pressure sensor then should there be a wire going to a gauge? btw, I don't have a manual to refer to yet. Thank you, John
sudo apt-get purge 930
That's the boost pressure sender. Not sure why it's wired to the coil. Does the boost gauge work? BTW, it should only have one wire just like the pic shows. It should be connected to pin #13 on the 14 pin connector.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
I'll double check, but pretty sure it was connected to the coil. I was being distracted by an inquisitive 3 yr old...
![]() I also saw this "green wire" bare. Is there a replacement for this or is the general consensus to just repair th section.
The green wire needs to be replaced if the casing is broken. If you have the two prong plug get this: Pelican Parts - Product Information: 930-602-907-01-M14
If it goes straight to the CDI get the 928 version as it's about 30" long and you can wire it straight to the CDI:Pelican Parts - Product Information: 928-602-907-00-M100)
it's not connected to the coil just kinda disapears into the wiring harness near there. yours looks like it's connected correctly.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
wire
No idea. I was only started briefly and shut down. It has a few ignition issues that need to be checked and squared away. I am almost embarrased to ask. Is the boost gauge the one with in the tach or the one to the right of the speedo? Ask me about a mid year vette... I'm so embarrassed to ask that. I need to do some reading... is all I need to say.
Turbofrog
The one under the tach. The other one you have is aftermarket and I think more accurate also. My original is not working and stays full boost all the time.
Let's see some detailed pics of the engine and interior so we can get an idea what you have. It will make helping you much easier for us all. Besides, we all like to see pics of cars
Whoa, whoa, whoa! First things first. Did the OP post pics of his car?
I'm on my iPhone and can't tell...
Wayah Road Warrior
Actually, it could be both. Clearly, the factory gauge below the tach would be present and the clock was sometimes replaced with the 934 style gauge as well. Some cars one or the other is the only functioning boost gauge. Other cars have both functioning. I tend to trust the 934 guage over the standard. Pic stolen from someone else's thread ...
02 996tt White 87 930 GP White (Sold) 87 911 Targa Guards Red(Sold) Last edited by Shadetree930; 06-15-2010 at 10:43 AM.. |
Let me see what pics I have...
I'll have to ask my partner what he did with the camera...
I would rather be driving
Great helper! that engine must not smoke much since you have ancillary mosquito abatement hanging on the rear panel.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
911/930mtr
Okay here are some pics. Some are from a phone others from an slr.
It's a "driver", but that's what I wanted. No worries from stone chips just adds to the character... ![]() ![]() ![]() polished Fuchs ![]() ![]() ![]() ![]() ![]() ![]() ![]() When it's clean, I'll do some decent pics. |
Turbofrog
Hmmm. I would keep 'helpers' away atleast the time the hoses are open. You don't want to be sorry later if something funny is found on your turbos compressor wheel ![]() Think: "Superman toy likes to go to investigate the black hole" |
I have a clock where your aftermarket boost gauge is.....think i prefer the gauge!!!!
"Racing is life... everything before and after is just waiting." Steve McQueen as Michael Delaney in 'Le Mans' |
Nice looking car. I seeyou have a Dial-o-Death on the center heat control. I'd be very weary about using that, as it's been known to cause instant engine damage. Do you know what boost spring you have? What's the 2nd dial on the heat console?
