Canucks Fan
Saw a vidieo clip and when the guy poped the rear lid it lifted by itself???
87-930 stock tail, when I pop the rear lid it just un latches, is that the way they work, you have to lift the lid, or it suposed to open when un-latched? What does yours do. |
sudo apt-get purge 930
Mine does the same as yours.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
I just installed...
4 new shocks on mine and it still lifts the way yours does!
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Non User
Me too, and i have a lighter turbo carrera whaletail...
Infraredcalvin - AKA Pat '76 Turbo Carrera #311 - Factory LSD, Sport Seats ‘71 914-6 GT 3.4L twin plug track car '75 914 GT clone project '71 914 track car, fresh 2165 FAT motor (for sale soon) |
R.I.P.
mine just pops as well. but once i lift it up a few inches the shocks take over and push it up.
we are talking about the car right? if not, try Viagra
I have to do a reach around to get mine to pop up while pulling on it. Maybe it needs lube or something? When it does pop up, I need assistance from a prop rod. Oh! the days when my shocks were young and spry...
A word of caution: Make sure the shaft isn't bent, which will cause the tension to load off-center in the latch...and may hang up and not release when you pull the cable. Been there, done that when I first attemted to adjust things back there. Couldn't get the lid to open at all, and there is no way to get to the latch to force it open in such an emergency. You're basically f - - ed if that happens. You have to resort to giving the lid a bear-hug and wrestling it sideways/up and down/round and round with all your might to get the lid open again.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
I hear ya. With all the wirk I've done, this piddly thing just keeps getting put off
My next work out will be checking the front tires. They both lose all the air in a week. They are 3 piece BBS race wheels I installed new tires on 6 months ago. |
Tinkering Pays!!
no wonder you 'hesitate' to take a trip in it...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. |
Driver
Oh yeah, my rear decklid just pops open with the release, and then I have to lift it up manually.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
I just recently installed new stabilus shocks while replacing the engine pad with a new lightweight one from our host.
The engine lid still needed a boost for the latch to release. After adjusting the position of the latch , it now works fine. The lid should not lift by itself until its lifted about 8 inches or so. You have to be real careful in adjusting the position of the latch rod, if it jams in the lower jaws or is incorrectly aligned, you could be in for a long day trying to open the lid. I had another 930 a few years back that i installed another spring inside the original spring to assist in getting the lid to pop open, that did the trick.
1978 930 Eurocar, steel slant. k27HS, Powerhaus IC, SC cams, RarelyL8 muffler....., 2002 Mercedes CLK55 AMG Cab, chipped, Previous and dearly missed: 1965 911S, 1970 911T, 1974 911S, 1978 930, 1982 930, 1950 Mercedes 300, 1988 Mercedes 560 SEC Convertible |
When adjusting, do it a little at a time or you'll be sorry.
