Me like track days
These will be available in about 2 weeks.
Charles said the 3.4 98mm 8:1 Turbo P&Cs currently retail for just over $6000 per set in raw state new from Mahle.. Charles Navarro LN Engineering Nickies The Original and Genuine CNC Billet Aluminum NSC-Plated Cylinders is taking these P&Cs with only 25 hrs on the set & working his magic on them, making them BETTER than brand new. There is NO detonation damage anywhere, they are lightly scuffed and need very little work to make them flawless and better than new. They will be incredible. The pistons will have Charles' recommended Calico Coating done on the pistons: ceramic coatings, teflon coatings, thermal coatings solutions with Calico Coatings Mahle is the standard for 930 P&Cs, and Charles will make them even better. Perfect bolt on setup for your 930, at less than new. Price? Not a clue. What's fair? 4500?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
