I want to install a 87 dash in my 84 930 easy?
I did a search and was not able to find a post which covers this topic.
I want to install a 87 Dash in my 84 930. Is there any welding required to replace the defrost vents? If yes, what parts do I need to get? Are these wrecking yard parts only or does Pelican have them? Thanks in advance SmileWavy |
I might be interested in this also any body have the knowledge?
There is a thread on here or Rennlist where somebody did that with pictures. They did some sheetmetal cutting to get the side AC ducts to fit and work.
maybe some searches here, rennlist, and google or dogpile.com will dig it up. |
You can do the dash top with the larger center vent fairly easy..
If you want the larger side vents.. then you're in for some "cut, chop, build" or should I say weld.. in addition to the parts need from a donor car. |
All Iwant to do is replace the Upper Dash. I searched the this forum and the internet and have not been able to find any info. When you say its fairly easy...do you know if I need to change/cut/weld the top defroster vents? Or do I need to change anything in the front compartment area where the hoses connect to the defroster vents? Thanks SmileWavy |
You will have to cut a bit of the metal for the center vent to fit. Nothing else to really change, nothing in the front compartment to change. It's one of the jobs that pretty straight forward and you'll see what you need to do as you move forward with the upgrade. Of course you'll need to remove the windshield. |
| All times are GMT -8. The time now is 01:35 AM. |
