Toofah King Bad
Wastegate Gasket
Looking for the round asbestos-looking gasket between the lower iron part of the wastegate and the upper aluminum can (or, reasonable alternative). I was originally thinking heat insulation was the primary purpose for the part, but then realized a boost/vacuum leak could also result from this gasket failing.
How hot do you think the top of the WG gets? I am looking at different materials, one being teflon, which is supposed to be good to 500°. Thanks, Rasta
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Manassas, VA
There was a Pelicanite that was making those gaskets. He told me to use two of them and some copper gasket spray during reassembly. It worked great and I have never had a leak since then.
I think the pipe would go over 500 degrees when the waste gate valve lifts. Mark
1991 964 Polar Silver Metallic Turbo Coupe |
Pretty common failure part on stock WG's. Mine was leaking there as well, and I gooped (sandwiched) some sort of high-temp epoxie there as a short term fix. Pretty crude, yeah, so don't flame me. But it worked until I lost confidence in the WG due to valve guide excessive clearances and leakage there. The solution: Tial
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Toofah King Bad
Well, the Tial will have to wait until I win the lotto. I actually have a new valve guide, so the gasket is all I need to do a good refurb.
