Turbo size question
Can someone tell me what size exhaust wheel a k 27 turbo has, i am building a turbo from precision turbo. I know the compressor side is a 60 trim but cannot find info on the exhaust. Please help. If i am correct a gt35r has a 70trim compressor and a 102 or 103 exhaust side. Thinking of going with a 61 trim compressor and an 85 exhaust
thanx |
The exducer size is the import part of the turbine at 58mm. Note that the ratio between the cold side and hot side is a factor in sizing to. For some reason a CIS turbo seems to get real happy with about a 60mm compressor inducer.
A ball bearing K27-7200 sized turbo would be interesting. http://forums.pelicanparts.com/uploa...1286376775.jpg |
911st
911st i tried to p.m. You but your box is full, just sent an email, i am interested in your cross over pipe!
Tim |
Thx.
| All times are GMT -8. The time now is 03:37 PM. |
