Car pulling to one Side
I bought this Euro 930 in 2008. I immediately changed many parts to get it back into my acceptable condition, which included the front brake Disc and brake pads front and rear. Tires all round was also changed. Since then, I cannot get the car to brake straight, without pulling to the the left. Hard braking will cause the left wheel to lockup and pull to the left. Brakes Calipers was serviced and Alignments and Various corners height was done and tried many times with only slight improvement. I dare not drive the car over 60mph due to this pulling to left. Finally yesterday, I swapped the front brake pad left to right and right to left. Guess what? It now pull to the right, not as bad but can managed to braked with straight line. Went to a local shop and bought and fitted a set of FERODO brake pad for the front. Works very well and straight line brake excellent with less effort.
Now the rear is still fitted with the "QUALITY FRICTION" pads that I used in the front. I'm going to change them out too. Should I go for the FERODO or should I order a set of JURID.
Lesson learned. Brake pads can be the culprit of pulling to one side. - Cheers
Old 11-20-2010, 04:39 PM
