930cab89's Avatar
What goes here???
When rebuilding my engine, I discovered these two holes and can't remember what should go there. Any suggestions?
Uploaded with ImageShack.us
Old 01-17-2011, 02:25 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Bracket for the sensor (TDC I think)
Who Will Live... Will See
Old 01-17-2011, 02:47 AM
930cab89's Avatar
I don't have this sensor, is that ok?
Old 01-17-2011, 05:20 AM
A930Rocket's Avatar
I don't have those bosses or sensor on my 87.
Old 01-17-2011, 08:03 AM
JJ 911SC's Avatar
Its in the 84-86 Cat and its called "Support For Pulse Sender".
Check the 89 Cat
Old 01-17-2011, 09:09 AM
A930Rocket's Avatar
Is that for a 930 or 911?
Old 01-17-2011, 10:20 AM
930cab89's Avatar
a 1989 930.
Old 01-17-2011, 10:34 AM
A930Rocket's Avatar
Strange it's on the 89, but not the 87. Doesn't the 84 and up Carrera use them as part of their Montronics?
Old 01-17-2011, 04:04 PM
JJ 911SC's Avatar
It's in the 89 CAT (#52 on Illustration 101-10 pg 1&2) part # 930 101 191 02; Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
Old 01-17-2011, 04:45 PM
TurboKraft's Avatar
Those are unused on the 930.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 01-18-2011, 11:07 AM
930cab89's Avatar
Ok, thanks. So nothing goes there.
Old 01-21-2011, 05:18 AM
j930's Avatar
dont forget the ball bearing under the oil pressure sender. IM not a mechanic but is that the fly wheel in the picture? My mechanic said we we do a reseal or a rebuild that should be balanced.
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 01-21-2011, 02:59 PM
930cab89's Avatar
Yes that's the flywheel. Thanks for the ball bearing. I found this ball on the floor after disassembling the oil line and was wondering where it came from. After looking in the parts diagram, I found the location.
Old 02-01-2011, 06:30 AM
j930's Avatar
no problem, I just checked to make sure I had one the day before you posted this, i guess if its not there you can get oil backing up into the turbo or something?
84 930 Slant
15 Sonata 2.0T
08 Ram 1500
15 Ram Eco Diesel
Old 02-01-2011, 07:01 AM
