-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   removing #1 and 6 spark plugs? (http://forums.pelicanparts.com/showthread.php?t=586234)
twin plugged targa 01-18-2011 05:08 AM
Can anyone advise best way to access and remove #1 and 6 cylinder spark plugs-
under the distributor and at the back right side - under air filter
Do I have to remove the IC and the air filter casing/assembly?
- For the IC is it just a matter of removing hose clamps and then pulling up to release the O rings?
- for the air filter assembly or filter 'end piece'(?) I undid the 2 visible clips in view but it seems to be hinged? are there clips at the rear or some other reason it will not come off?
Many thanks
Ben
totle 01-18-2011 07:01 AM
Hi Ben,
IC is connected with 2 bolts rear (under IC from rear), 1 bolt on front left side and 1 bolt front right side. All 13mm bolts. Then just pull up to release O-rings.
Air filter is connected with 2 10mm bolts on top of the air filer and with 1 13mm bolt under, right above WUR. Also there is a hose connected in the rear for oil breather.
I also remove the 90 degrees rubber connection for the downpipe to easy reach cyl 1-3
twin plugged targa 01-18-2011 11:19 AM
Thanks very much for the help- does'nt sound so difficult now!
I will attack the last plugs this weekend!
cheers
Ben
