9dreizig's Avatar
Send a message via AIM to 9dreizig
valve adjustment
So adjusted my valves on my last engine drop. First time, followed the book. They were tight as hell before I adjusted them (couldn't get a guage in them and REALLY cranked down).. So now my buddy tells me they are a little loud. Apparently a common rookie mistake is not cranking them down far enough.. So my question is if they are a little loose how much damage will you do running them for a little bit? The engine is running GREAT. I'm not even sure they are out of spec but he's got me thinking....
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 01-31-2011, 10:12 PM
MikeD930's Avatar
What do you mean a little loose? Are you referring to a lock nut or valve clearance? That two different issues. A loose lock nut needs to be addressed asap. Whereas a loose valve clearance would be noisy and lose some HP.
MikeD '87 930
Old 02-01-2011, 06:29 AM
9dreizig's Avatar
Mike, sorry for the confusion I am refering to the valve clearance. Lock nuts are all snug.
So no harm other than a little loss of power running it that way for a while ?
"Todd"
Old 02-01-2011, 08:46 AM
beancounter
jwasbury's Avatar
Todd,
Tight clearances will do damage (burned valves). Loose clearances, not so much (within reason, of course). They would need to be pretty far off for you to notice a power difference IMHO.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 02-01-2011, 09:00 AM
