electronic csi controller
Greddy rebic IV fuel injection controller used to control a frequency valve to vary the control pressure at the fuel head. Uses map and rpm signals along with frequency valve settings to create a smooth A/F ratio throughout the entire rpm range. $550.
http://forums.pelicanparts.com/uploa...1300156790.jpg http://forums.pelicanparts.com/uploa...1300156809.jpg http://forums.pelicanparts.com/uploa...1300156819.jpg http://forums.pelicanparts.com/uploa...1300156829.jpg http://forums.pelicanparts.com/uploa...1300156838.jpg http://forums.pelicanparts.com/uploa...1300156848.jpghttp://forums.pelicanparts.com/uploa...1300156892.jpg |
Can I use this with my factory installed Frequency valve used for lambda control? Obviously assuming I eliminate lambda control.
Yes, if its connected between the fuel distributor control pressure side and the return line to the fuel tank your original FV should work.
| All times are GMT -8. The time now is 04:26 PM. |
