Turbo Oil Supply Question
I am installing the 930 oil supply set-up and I have one question.
I there supposed to be a crush washer under the oil light sensor? It does not look like there is one on the part diagram?
If I add a washer the sensor does not full tighten down. If I do not use a washer, it tightens down in to the housing.
Thanks!
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!---
-2001 996 Turbo
Old 04-25-2011, 04:02 PM
stevie 77 930's Avatar
There is a small crush washer on the the pressure switch. You cant see that washer in the photos, but its there. Here's a picture that shows how it it suppose to be...first 2 pictures are from my rebuild the last one was posted here some time ago. Dont forget the ball check valve .
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 04-25-2011, 04:29 PM
Thanks Stevie,
Maybe I am using the wrong type of washer. The copper one maybe too think which doesnt allow the sensor to seat.
Jeremy C.
-2001 996 Turbo
Old 04-25-2011, 05:24 PM
proffighter's Avatar
If I remember correctly, it's a M10 aluminium washer, same as on motorcycle brake line banjos
Roland
930 Turbo '81 Too many modifications to list
Old 04-26-2011, 12:11 AM
That washer comes with a new pressure sender. Not sure why it wouldnt tighten down with the washer installed, unless the "eye bolt" is stripped inside and you lost some threads, strange.
1983 911SC
2018 GTS
2023 Audi A4
Old 04-26-2011, 11:12 AM
Jeremy
I am not sure about you're needed washers for pump. I cannot remember for some tapered fittings. So here is my set-up:
#1 is the Idiot light, should be M10 (you measured 9.2mm)
#2 is probably 14mm
#3 is then 16mm (need 2)
Roland
Old 04-27-2011, 02:16 AM
Thanks Roland.
For clarification, I do not have the banjo style AN fitting on the inlet side, just the standard fitting.
Jeremy C.
-2001 996 Turbo
Old 04-27-2011, 04:05 AM
Also does the pump have to mounted in that orientation? Right now I think I have it rotated counter clockwise (compared to yours) and the inlet is at the "2 o-clock" position.
Thanks again.
Jeremy C.
-2001 996 Turbo
Old 04-27-2011, 04:07 AM
I have the pump in the stock position, but nothing against to fit otherwise
So you need a total of 3 washers then...
Where was the tapered thing?
Roland
Old 04-27-2011, 04:25 AM
It is in the inside of the fitting I have for the inlet. only seems to have a slight taper on the inside of the fitting.
Jeremy C.
-2001 996 Turbo
Old 04-27-2011, 04:40 AM
Maybe you make a pic of it, but it seems to like this, then no gasket needed
Roland
Old 04-27-2011, 04:49 AM
I will get you a pic.
The reason for me to rotate the pump, is because the plan is to dump the oil back into the lower drivers side valve cover and not into the oil tank. I was just curious if rotating would have any effect on the efficiency or effectivness of the pump, but would not think so.
Jeremy C.
-2001 996 Turbo
Old 04-27-2011, 05:24 AM
