Clamping force of Sachs "sport" pressure plate
Anyone know what torque rage this PP can hold?
88 3082 999 594
Description: Clutch Pressure Plate "Sport"
Manufacturer: SACHS PERFORMANCE
Drew
86 930
Old 04-22-2011, 04:23 PM
TurboKraft's Avatar
-754 or -574?
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 04-22-2011, 05:28 PM
Oops,
wrong number.
it's 88 3082 999 594
Drew
86 930
Old 04-22-2011, 05:29 PM
Chris,
I think I may have spoke with you earlier this year about a possible Carrera type hydraulic set up on my 930...I have the RUF 5-speed. Heard about you from Lincoln Philips here in Michigan. Do I have it right?
Drew
86 930
Old 04-22-2011, 05:36 PM
TurboKraft's Avatar
The Sachs Sport -594 (aka Ruf) pressure plate will handle all the torque a typically modified CIS-injected 930 can make.
#88.3082.999.594 = 3.0L-STLYE 930 SPORT ALUMINUM PRESSURE PLATE
Approx. 11.0lb, 13.6lb with bearing & extension (vs. 25.4lb stock iron part)
Clamping = 11,100 - 12,200 N
Torque rating =
465Nm organic (ex: original 930 disc)
540Nm special organic
595Nm sintered plate
Yes, now I remember our conversation.
We could convert that 930 4-speed to a hydraulic operated clutch. Pedal effort could be as light as you need it -- effortless like a 993T or Honda Civic, for example.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 04-22-2011, 06:55 PM
Chris,
Wanted to get the basics all done to see if that cured the problem. I now have a new clutch cable, rebuilt pedal cluster. Gonna try and lube the Guide tube through the inspection hole to see if this takes the pressure off. Clutch is old, maybe 8 years, but has only about 12,000 milles on her. I don't know if they simply get stiff from age alone.
If this doesn't work I'll replace the clutch here in the next month or so after talking to you and getting your input on what to get.
If this is a bust, it goes off to you for the ultimate mod to make this car enjoyable for everyday driving.
Thanks Pelican for this forum!!
Thanks Chris!
Drew
86 930
Old 04-22-2011, 07:11 PM
