Photo of CRACKED CYLINDER due to OVER BOOST, Our Worst Nightmare
Photo of CRACKED CYLINDER due to OVER BOOST.
Our Worst Nightmare. If you don't watch your boost gauge, you will never know if you develope intermitant boost creep. A Tell Tale Boost Gauge will record your highest boost since you can't be watching it all the time.
sudo apt-get purge 930
Trying hard to sell that boost gauge huh?
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
89 930.
lol
Hi Guys,
I wasn't laughing when I had to find a single 3.5L Mahle Cylinder. Thank God for Pete at Andial. |
How do you know it was due to overboost - boost creep, you call?
newby
I have to say that I'm worried about this - I have an 89 930 that I've just had serviced by a Porsche Specialist in Brissy - these guys really know there stuff and have 20+ years building race cars etc - they sent off my WUR, injectors & Fuel distributor for a refresh after my car was not coming onto boost smoothly.. Since it's been refreshed Wayne Park (Race Car driver & mechanic) has the car sorted and running so well that it's now scary fast. His words were it's the fastest 930 he's ever seen or driven and estimated HP at about 500 .. I've had the car since October and the Previous owner knew nothing much about it, he bought it 'cause it looks pretty . The car has a 1.5 Bar spring in and breaks traction easily in 1st 2nd and 3rd in a straight line .. I'm running 98 octane with an additional Octane booster to give it the fuel it needs - Wayne advised me that the car has had a lot of $$$ spent on it to get it to where it is now so spending more $$ to make it slower didn't really make sense.. Give it the fuel it needs and you'll be fine .. But I still have concerns about over boost .. But the car does run VERY well now that it's been tuned properly .. Don't want any blown motors ..
1989 Black 930 3.3 964 Turbo Motor 5 Speed Ben Clark Photography Website: http://www.benclarkphotography.com.au See our latest work:http://www.benclarkphotography.com.au/blog Associate member of the AIPP - Aust Inst of Professional Photographers |
I thought there were built in fail safes to prevent this, but I was wrong. If your wastegate lines fail or your wastegate diaphragm deteriorates or the diaphragm becomes slightly pinched during installation while blindly compressing the spring, you can overboost.
We are in more danger then we realize if we can't relieve that excess pressure. When the rings break and the cylinder cracks and the pistons are not fried, then it was overboost and not detonation due to a lean fuel condition. I had Raceware head studs so they didn't fail so 'Pop Goes the Weasel' and the cylinder cracked. Last edited by NY930; 08-14-2011 at 07:19 PM.. |
How high did it have to go to deliver the damage.
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 |
How did you realize or what symptoms did you experience to lead into tearing into the engine?
Ole Skool - wouldn't have it any other way |
Well that's the problem.
Our factory boost gauges only show .8 & 1.0 Bar Boost. I thought that maybe the previous owner had installed a 1.0 Bar Spring. So there's the problem. The stock boost gauge does not indicate a overboost situation over 1 Bar of overboost. |
Hi Slow & Rusty,
You sound like you have an old 356. That's how my 356 was. Very slow and very, very rusty. To answer your question above, under wide open throttle during full boost, I heard a POP and then an audible exhaust leak before the exhaust port. What a bummer. |
Sorry to hear that.
Tony 91 964 c2 black/ Work in progress/Finally back on the road 85 EURO 930 Black slightly moded slowly reviving her 77 911tt EFI wide body red/ Slightly modified ![]() SOLD
LOL
So it will let you know how much boost it took to crack a jug, awesome.
'89 911 M491+Turbo '90 964 C2 '89 944 Turbo '88 928S4 |
Lincoln Phillip 87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound. Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs. "the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker |
That's the equivalent of 93 MON in the USA. What kind of intercooler are you using? I'd turn that boost down before you blow that motor. All it takes is a few seconds under load and BANG!!! 1.1 - 1.2 bar is probably safest for a well sorted car on our pump fuel. |
newby
It's running motronic, the motor is a 965 - not sure what difference this makes .. Is CIS and Motronic different ??? I'm new to these cars ..
![]() Yasin
Infidel
Is it a stock 964 turbo? If so it will be CIS (K-Jetronic). Do you have a picture of the engine, we'll be able to tell you straight away what you have.
Jonathan. 87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines..... Old 540 BMW, XB12S Modified, for being a total hooligan
I've seen it in another thread, it's K-Jet, if it's making 500hp and holding together at 1.5bar, it's a very special car
Banned
NY930... what about your overboost switch cutting the pumps @ 1.2bar? Both the WG and that have to have failed to overboost for any amount of time beyond a very brief (and very violent) second.
Er, why you selling the gauge - seems you're touting how much it's needed to prevent blowups? Just querious... |
