-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   What do you think of this intercooler for a twin turbo? (http://forums.pelicanparts.com/showthread.php?t=627795)
MrShades 09-02-2011 10:11 AM
I have a 1985 Porsche 911 twin turbo and i have been thinking of replacing the intercooler
I found these two. How do you think they fit on a 1985 911?
One thing is that i would like to have the outlets to the turbos pointing down instead of to the sides
On th first one i would like to have the inlet pointing straight forward to the engine as well.
The first picture of the intercooler is upside down.
Measurements is 27"x13"x7"
http://i414.photobucket.com/albums/p...tercooler2.jpg
http://i414.photobucket.com/albums/p...ntercooler.jpg
Or this one. Measurements is 29"x13"x7"
x98boardwell 09-02-2011 02:07 PM
As long as the inlets or the turbos were facing down you should be good.... But have others measure the width of there's to be certain you are not too wide.
I know nothing about the companies quality, flow rate, or efficiency either... Mybe someone else could help with that.
Bryan
JBL930 09-02-2011 03:02 PM
The 'Just Intercoolers' one has a lot more cores, and the fins 'look' tighter packed.... My money would be on that one having better cooling ability.
This thread is a good read 9M Prototype intercooler test report - Rennlist Discussion Forums Results on different coolers, and as you can see the better performing ones has more cores and really tightly packed fins. These are high end coolers, the best one being a Secan, i'd look to copy it as best as possible
RarlyL8 09-02-2011 07:59 PM
I thumbnailed the GodSpeed unit several years ago but never got around to finishing that project. You have to wonder what the difference is between a $300 intercooler and a $3000 intercooler. Besides being made by slave labor in Asia what is the structural difference that drives up this cost? How much more efficient are the expensive units?
jackwangs 09-02-2011 11:45 PM
well, good note ah, ha ha
MrShades 09-03-2011 01:51 AM
I suppose there is quite a difference but it would be fun to check out the cheap intercooler.
I can easy convert the intercooler so the outlets points down to the turbos
I suppose the to outlets goes to the turbos and the inlet to the engine;)
Have a look at the picture and tell me what you think. Note that the overall lenght will be shorter because the outlets to the turbos wil be on the underside.
I have tried to mark it with grey arrows
This is the info about the intercooler:
http://forums.pelicanparts.com/uploa...1315039789.jpg
Length 29"
Length (Core) 24"
Height 13"
Height (Core) 7"
Thickness 3.5"
Inlet 2.5"
Outlet 3"
Compress Air Flow Rate <700Cubic Feet/Min, Rated to 600-700 Max HP
Working Pressure: 5~50PSI
Pressure Drop 1~4psi@35psi; 0.2~0.5psi@15psi
Hot Air Temperature 32°F~302°F (0°C~150°C)
Material 100% Aluminum
Design Bar and Plate
Construction Machine Cut and Stamped, Hand Welded
Finish Polished
Net Weight 22 lbs
Tell me what you think of the description of the intercooler
slow&rusty 09-03-2011 02:43 AM
Cheap Intercooler versus Expensive one..data here:
Supraforums.com
CobraJet 09-03-2011 03:55 AM
Supraforums.com
I hate it when forums make you have to creat a username and password just to browse......
:rolleyes:
Tilikum Turbo 09-03-2011 07:10 AM
Exactly...if it wasn't designed/developed for that engine, it may sound good from a price standpoint, but the end results most likely be less than desirable.
Since no 1974-89 911 turbo engine came from the factory with twin-turbos, that application may be even more ambiguous.
Caveat Empor'
