red vs black fuel pump relays
i just read last night in another thread (i cant seem to pull up right now) there is a difference in the red and black relays
red ones have a diode and black ones do not
after looking at my car, i have all black ones. maybe replaced by previous owner?
should i replace with correct red ones?
Old 10-24-2011, 05:51 PM
DSPTurtle's Avatar
If you had all black ones, your car would not shut off with the over boost sensor and the CIS throttle plate. Are you sure you have ALL black ones? How about the one in the back by the engine
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 10-24-2011, 08:10 PM
pretty sure
where is one by engine? behind cover in back left corner?
Old 10-24-2011, 08:15 PM
DSPTurtle's Avatar
Yes sir. Pull that plastic cover off and you should see a relay. Actually, yours may be of the "yellow" variety. That's okay too because it has the built in diode.
By the way... on a funny note, today I looked at an '89 and every single relay was red. Apparently the factory just gave up in '89 and decided to make them all red. Changing a black to red is no big deal. Changing a red to black (if you need the diode in that particular circuit) is bad mojo. I don't know why I buy any spares in black... oh yeah, they are cheaper.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 10-24-2011, 08:49 PM
