930 turbo axel problem.
Hy there.
I have a 78 930 and 3 axles have broken(the stubs that go through the wheelbering). It has a G50 box and new cv joints and hollow shafts g50 box and plenty of horses, 650 whp. The car got a big died, from 1240kg to 1100kg using carbon fiber body parts. My tires are Michelin pilot cup 335 30 19. wheel is 19x11.5 Where can I find a good upgrade for my proplem. Please help. :)http://forums.pelicanparts.com/uploa...1324343619.jpg |
Here is the axle eater.
http://forums.pelicanparts.com/uploa...1324346775.jpg |
no help on your axles, but 2400 lbs.... nice! I am looking to under 2500.
Vidar:
You might give Chris Carroll at TurboKraft a call I'm sure he could at least point you in the right direction. Cole |
Try MODE in Phoenix AZ area or Patrick Motorsports also in that area.
Do you have an LSD? What model G50 and do you have a billet side cover?
What about the sand rail guys? They are putting some serious hp through G50's but not sure if they just use the CV's, but not the stub axle. |
Mark Williams Racing can custom make any axel you need, up to 5000hp. They make them for drag racing and nascar.
there was a post on here somewhere from reaper. got some off road axels for less than stock ones.
| All times are GMT -8. The time now is 10:46 PM. |
