-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   i know its been asked,...how much fluid for 930 trans (http://forums.pelicanparts.com/showthread.php?t=649762)
jimtweet 01-09-2012 10:25 AM
every thread i have read says to just fill it till it starts to drip out the fill hole...
1. my trans is out of the car, and back from a fresh rebuild
2. i want to make sure i order enough fluid (swepco is sold online, so i wont be able to run back and forth to store)
1980 930 transmission. thank you. i really need to get my hands on a manual.
gsxrken 01-09-2012 11:04 AM
Manual says "Approx 3.7 L SAE 90 oil of API Classification GL 5 (or Mil-L 2105 B).
JFairman 01-09-2012 12:13 PM
just under a gallon goes in.
philip j 01-09-2012 01:14 PM
Did mine...
on the weekend. Since the tranny was out of the car, I flipped it on it's side and put the whole jug of Sweptco in. Once it's installed, I'll pull the fill plug and see what comes out. Philip
gsxrken 01-09-2012 01:45 PM
Just make a note in your logbook or tape a note to the steering wheel. That's an easy one to forget in the scheme of things.
jimtweet 01-09-2012 02:09 PM
that is why i want to fill it now, i also dont want it sitting around for a couple months with no fluid in a cold, damp garage
Panzer Slayer 01-09-2012 06:21 PM
i changed my trans fluid over the weekend also, I have a 87 930. I pumped in Swepco until it started dripping out but it looks like less than half the gallon jug was used. Did i do something wrong? It was on jack stands with a slight rearward bias? I guess i put something like 1.5 liters in there max.
mike f 01-09-2012 09:17 PM
Did you make certain that all the old fluid drained out? Like others have stated, mine took almost the full gallon. 1.5L is way too little. I don't think a slight rearward tilt is going to make that much of a difference. I would try removing the drain plug and catch the newly added fluid into a clean bucket. Make sure it is all drained out and refill it with new fluid and/or the previously added fluid if it is clean and not mixed too heavily with old fluid.
cole930 01-09-2012 09:55 PM
Jim:
The Old Sled is also an 80 ROW with the original 4 speed. I just filled the trans and it took just short of 1 Gal. I used a long flex funnel and filled until fluid started running out, I continued to let it drip into a catch can until it stopped, stuck my finger in fill hole and the fluid was still at the hole.
There was just less than a quart after I finished.
Cole
equality72521 01-10-2012 05:40 PM
Originally Posted by cole930 (Post 6484175)
Jim:
Cole
Same for my '79 ROW.
