rrental's Avatar
Air injection belt replace or not?
Finally got some time to go over the engine bay. Planning to replace some belts and found half a belt in the far left corner. It's the air injection 70t belt.
I have been reading up a bit and it seems the air injection is only needed for smog purposes.
I don't have the time to remove the complete system but would it be ok to leave it without a belt, as in non working?
Thanks!
Old 07-25-2012, 10:57 PM
Certified User
billjam's Avatar
Yes, leave it off.
Consider it weight saving.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 07-26-2012, 05:13 AM
rrental's Avatar
Originally Posted by billjam View Post
Yes, leave it off.
A massive 0,2 lbs weight saving! Looks like a PITA to put a new one on.
Old 07-26-2012, 06:52 AM
I've gone native
Tt surgeon's Avatar
I would ditch the air injection and plug the holes while you're at it....
'07 997.1tt
Blk/blk 600hp, bad to the bone
Old 07-26-2012, 08:15 AM
Telerding's Avatar
I'd be careful about just removing the belt. I have heard and experienced on US cars that stopping the air flow can lead to burnout of a check valve that keeps exhaust gas/flames from exiting into the air injection pump hoses and the pump itself. Some of the hoses may be just rubber. Could lead to an engine fire??
I would recommend that if you want to leave the air injection system disabled, that you remove all the components and plug any exhaust fittings. Save the parts, though, as next owner may live in a state that requires smog equipment.
1986 930, Garnet Red Metallic
Previous P's:
65 911, 66 911S
63 904 (086), 63 904 (038)
70 914-6
Old 07-26-2012, 10:38 AM
rrental's Avatar
Thanks for the replies! did have some time left today and decided to rip the system out. Left the tubes on the bottom for this winter when I got a bit more time.
Took a 2 hour test drive and all is well!
Old 07-29-2012, 07:29 PM
Smart quod bastardus
fredmeister's Avatar
There are lots of postings on removing the spider web and plugging the exhaust ports with fittings.
As long as the govt wont bust you for smog equipment, you should be good.
Pelican sells the little plugs which also are used for 914 brake calipers, dont remember the part number/name.
But what I want to say is buy a few spares because occasionally they blow out on the road in the most inopportune times making for a noisy exhaust leak. First time it happens you will crap your pants thinking you broke a header, blew an exhaust port gasket or some other expensive problem.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 07-30-2012, 10:40 AM
