Monitoring AFRs what are my options?
What are the differnt systems you guys are using to obtain real time numbers in the cockpit and for logging. (besides in your face gauges as it seems they are nla) I used an LM-2 in the past but the cable was not quite long enough and the hand held device was large.
It depends on what you're looking for... I have a K&N unit which is enough for me - compact, accurate and under $150; if I need more accurate info I go to a dyno. You can spend as much as you want and still get the same readings. M2c
I would try searching on this forum, lots of threads on the subject..
I run the Innovate AFR gauge and it's all good. |
| All times are GMT -8. The time now is 11:45 PM. |
