Here is my AJR console complete... for now. :-)
http://forums.pelicanparts.com/uploa...1588277454.jpg |
Brian, a little late but here's what I did really cheap and easyhttp://forums.pelicanparts.com/uploa...1588281786.JPG
Is that a faceplate, possibly fastened under the dash, but overlapping the top of the center console? ...or is it fastened to the top of console? |
https://www.amazon.com/Aluminum-Double-Gauge-Holder-Autometer/dp/B00Y5HM3FE/ref=pd_bap_rp_25?_encoding=UTF8&pd_rd_i=B00Y5HM3FE &pd_rd_r=4a103e39-15c9-446d-ae16-c6156de34300&pd_rd_w=Lqjia&pd_rd_wg=WpiPf&pf_rd_p= 135d8f7b-4369-4c39-87de-1c8e5d39061d&pf_rd_r=8AWP9ZKJ7DEFZWHQKK3K&psc=1&re fRID=820332SKQZ6TJCFWSNSH |
Here is my solution. This one includes AFR gauge, an LED for the AFR sensor (too cold, too warm, error) and LED driven by the knock sensor, controls for my under-seat bluetooth amp, a USB charging port, and the logging/programming port for the microsquirt.
I can custom make these in 1,2, or 3 gauges for either LHS or RHS, or work with you to place other items in here. http://forums.pelicanparts.com/uploa...1588286486.jpg http://forums.pelicanparts.com/uploa...1588286500.jpg |
This is a hand made console, using lexan around the gauges made this easy without having access to fancy equipment.
http://forums.pelicanparts.com/uploa...1588422770.jpg |
The control pressure and volt meter are Glow Shift gauges, and AFR is Innovate.
http://forums.pelicanparts.com/uploa...1588676521.jpg |
| All times are GMT -8. The time now is 06:39 AM. |
