-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   CIS adjusting screw (http://forums.pelicanparts.com/showthread.php?t=698791)
sundevil64 08-25-2012 04:39 PM
CIS adjusting screw
I suspect this adjusting screw is not supposed to be this way? It's rounded at the end.
It's off of an 78 930. I was having some trouble turning the adjusting screw so I decided to investigate.
I may need one. Does anyone have one laying around they want to sell?
http://i475.photobucket.com/albums/r...2C10181D16.jpg
sundevil64 08-28-2012 03:59 AM
I cut it down and it seems to work fine. Hard to believe. Got used that much.
jsveb 08-28-2012 05:14 AM
Check that the adjuster itself is actually able to move rather freely. If if binds then it'll just round off again.
slyguy 08-28-2012 07:26 PM
ahhh that reminds me, need to pick one up. (or two to have a spare) The end can be ground a little but eventually it wont engage the 3mm adjuster. In a pinch you can use a long 3mm allen, just have to pull the adjuster each time. I replaced the flat head screws with allen to make it easier to remove and reinstall.
