-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   I hear flow noise on boost (http://forums.pelicanparts.com/showthread.php?t=709437)
gsmith660 10-02-2012 10:41 AM
It sounds like it is a screaming banshee and quite loud. I didn't have it before but now it it loud any ideas what it might be and where to look. I dont have any apparent leaks between the turbo and the throttle body
gsxrken 10-02-2012 11:12 AM
Orange o rings seem like a good place to start. Assuming you still have them and don't have the long neck sleeves.
I guess an intake port gasket could leak/whistle under boost, but I'd bet you'd also have a vacuum leak and other complaints than just when on boost. GL
Tippy 10-02-2012 11:18 AM
You have a blow off valve? Open vacuum port?
Tt surgeon 10-02-2012 12:25 PM
Waste gate?
Miguel Antonett 10-02-2012 12:57 PM
How did it start? out of the blue? w/o any progression?
Do you still have steady full boost at WOT?
gsmith660 10-02-2012 01:36 PM
Boost drifts down sometimes from full boost but not always depends on how it comes in if I boost fast it drifts off but if I bring it in slow it comes up and stays up. I was thinking wastegate still troubleshooting. Will check the intake gaskets that is a possibility I do have a BOV open to atmosphere but don't recall hearing that sound before I am going to take the filter off and see if that makes a difference. Thanks for the ideas and responses. Don't have the o-rings and I have 15-16 in vac at idle and 22-25 in vac at cruise a search for a vac leak today revealed nothing.
gsmith660 10-03-2012 03:02 PM
The car is just plain running like crap it has no get up and go and sounds terrible very sluggish. I am curious if my O2 sensor is going bad that would screw up my EGO corrections and make the car run terrible wouldn't it? Both times I took it out for a drive today at about the same time the LC-1 started blinking 7.4 ideas?
gsmith660 10-04-2012 03:27 AM
I am such a dufus! I just looked at the target AFR table that is default in tunerstudio and no wonder I have popping and crackling it is extremely lean. Can anybody please post an example of their AFR table for MS3 that they used for VE analyze live?
Tippy 10-04-2012 07:17 AM
This is roughly what I am trying to achieve. My car will run as lean as 16.5 but after that, it starts to surge.
http://forums.pelicanparts.com/uploa...1349360238.jpg
gsmith660 10-04-2012 07:36 AM
gsmith660 10-04-2012 07:37 AM
I think my O2 sensor is toast after going through the calib procedure after a few min. the gauge starts flashing 7.4
Tippy 10-04-2012 09:24 AM
What brand/model of WB02 do you have?
gsmith660 10-04-2012 09:49 AM
Innovate LC-1
